Hi All.
Well ok, so about a month ago i got my r33 with 72 k on the clock.
When the car i got the car, it already had a nice Jap muffler, i got the rest of the system made up, so now it's a full 3" exhaust including dump pipe and high flow catco cat.
The car has a HKS intake with pod, exhaust, boost controller set to 7psi stock cooler, untill the new ones goes on, a walbro GSS342 pump and pressure reg set to stock psi.
When i got the car, soon after it developed a miss in the high rpm range, pulled the plugs out and they looked like crap, so upon recomendations i got a new set of plugs BKR6EYA gapped at .8 mm. I also tryed 1.1 but got a miss and at 1.0 still missed, at .8 it runs fine.
I taped up my coils to be on the safe side, and it all seams good.
HOWEVER, i got an SAFC II, which is untuned for now, untill the intercooler goes in ect, and my economy sux.
I use BP ultimate, as that is all we have in TAS, and i get a mear 300-350 out of 50 liters, town driving, not floging it much or anything. I know it's a bit ritch as the car backfires durning gearchanges ect.
I replaced my O2 sensor with teh NGK item, along with the ECU temp sensor, i have no leaks, idle is fine, haven't cleaned my AAC valve yet, the computer is reset and still nothing more then 350 km.
What is up, i know the skylines run ritch and once the SAFC II is tuned it will be better, but dam, how do people manage to get 400+km out of a tank is beyond me, can somone help me, and give me some pointers as to what to look out for.
BTW, checked the timing and it's 15 deg as per manual, The only think i am thinkg of is that the plugs gapped at .8 might decrease economy?????
NEED some advice on where to go next PLEASE.
https://www.sau.com.au/forums/topic/134896-r33-fuel-economy-300km-on-50-liters/
Based on:
50L / 300km = 16.6L/100kms
50L / 350km = 14.28L/100kms
average of 15.44L/100kms doesn't sound too bad for a heavy r33
well the fuel tank is 65Litres so if your getting those figures out from 50Litres of petrol you've got another 15Litres in your tank so if you push it you could probably get away with getting 380-400km/hs before your tank is very very low.
my 2cents.
btw i'm averaging 17L/100kms city driving but thats with bigger fuel pump 550cc injectors bigger turbo.
i get an average of 12L to 100kms, and that doesnt seem to bad, i only just got this because i took off my apexi pod filter, the mods i am running is 5 1/2 inch exhaust HSK all the way through spitfire coilpacks, standard aircleaner with paper insert, apexi BOV, 7pound boost.
1996 SII R33 GTS25T
I have a fairly stock R32.
mods
catback
FMIC
boostcontroller set to 14psi
ECU remapped (not fuel map jst timing map)
I get 450km to a full tank (65 litres) and that is flogging it atleast once daily. If my wife drives it all week she will get 500k just.
I can drive to sydney and back on a tank. (about 560k's)
sorry I know this dosen't help. just offering a comparrison.
Well i haven't touched the setting on the SAFC II as yet, the car is booked in in two weeks for a tune to see how it goes.
see my post here for some more info
http://www.skylinesaustralia.com/forums/in...howtopic=134905
I figured the car would be good for atleast 400kms
a poorly tuned ECU, just like a carby - can and will run rich as hell and obliterate fuel economy.
I have ~194kw at rw, with similar mods (i have a PFC tho), and i see 300km/45L (15L/100) only if i thrash the living crap out of it.
Its all in the tune mate.
so lets hope the tune will fix it.
Other then that, can you guys point a finger to anything obvious that can couse higher then normal fuel consumption
nothing that isn't absolutely hilarious (if you're drunk) and incredibly unlikely...
lets say
hole in the petrol tank?
LOL, well last time i checked i was only mildly under the influence. LOL.
Nah fuel system all good, replaced ALL the hoses to new Hi Pressure EFI hoses, so no chance of a leak or anything.
where did you get tese Hi Pressure EFI hoses from? links and prices?
cheers !
Purple Pig, hi Pressure EFI hose about $19 per meter, and about $15 trade price, They have teh standard stuff for about $13. the only differance i saw was there is a lot more weve in the HI pressure one. Very nice hose
  • 5 years later...
i get 580 -600k on the open road @100km/h thats on a full tank ...i find u do 110 120 the fuel econ goes to the shit house... remember these are geared for japan not for australia though
my car has 157000ks on it stock as a rock
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
