Item: White Avantek Titaniums - 18 x 8 - Multi fit stud pattern. ie 5 x 114.3 and 5 x 120, will fit any car with 5 studs :thumbsup:
Item Condition: Near new, been on the car for 3 months now. No scratches or gutter rashes at all.
Reason for Selling: After another change
Price and Payment Conditions: payed 800 for the rims and another 800 for the tyres. Im after now $1200 neg !!!!
Extra Info: Tyre sizes/brands are:
225/45/18 at the front. Tyre brand is Michelin Pilot Sport 95% thread
255/40/18 at the rear. Tyre brand is Pirelli Pzero also 90% thread
Pictures: picture of one of the rims, but i can assure you all other 3 rims are in exact same condition.
Contact Details: pm here or email to [email protected]
cheers thanks for looking :D
Edited by SLYLNE
still for sale.. price drop $1200
or make a reasonable offer close to 1200 and ill consider.
cheers
Edited by SLYLNE
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
