Ok so
so far the car has got all the supporting mods
Walbro Gss432 pump
adjustable fuel pressure regulator
full 3" exhaust with dump pipe
HKS pod and intake
boost regulator
SAFC II
FMIC
New 02 sensor
New ECU temp sensor
I am running 7psi at the moment, and when i got o tune the SAFC II i want to run 12psi and no more, less if i can get away with it.
The tunner told me that 160rwKw is basically what is actually posible, i have no idea why, that is only a 40kw increase over stock.
Now basicaly intake and exhaust is a good 10kW, pod 5kW, 5psi boost 40kW, remap, about 10kW so that should be a total gain of about 65kw. Now stock at the RW is about 120-130kW so that should be about 180-190rwKw in total
So what the helll is he on about.
Can people post up their output figures with the mods. I am not too sure if the tuner can be trusted but that is the only one poeple have recomended.
What sourght of power figures should i be looking at, and what do i tell the tuner to do, ie fuel air rations and recomendations to my tune.
HELP PLEASE, i want to get this right, as i am on a budget. Thanks.
SILLY ME. she's a 1995 R33 series 1.5. Opppsa
Edited by WogsRus
https://www.sau.com.au/forums/topic/134905-car-booked-in-for-a-tune-safc-ii/
1.What car is this for btw? R32 Or R33 Or R34?
2. How much power is the car making now prior to installing SAFC + tuning?
3. What turbo are you running? stock?
4. If its a r33 with the mods you have listed on stock turbo i personally believe you'll be getting between 170-190rwkw as well. If its an r32 then 160rwkw is my guess.
my 2cents
remember auto's dont read aswell on dyno's as manuals do,
i was told by my tuner,he said it reads a little higher down low
(something to do with the torque) and read low up top.
89' rb20det r33 turbo+zorst & SAFC1 automatic = 165rwkw
12psi
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
