Hey Guys,
Firstly I did search but didn't find anything again!
Just a question regarding the 3 guages in the centre.
What size aftermarket will go in there?
How do ou get them out? Just pop the cover?
Is it as easy as hooking up the existing cables? (oil temp)
And also can i use the factory oil pressure sensor and wiring with an aftermarket guage??
Obviously boost and voltage will be easy. but the oil temp is the only concern?
Cheers
Josh
Edited by GreddyGo
https://www.sau.com.au/forums/topic/134928-r34-centre-guages/
hope this helps
1. pop out the aircon vents with a flat head screw driver on the lhs
2. remove two screws holding the center gauge.
3. flip up to remove.
Also do a search on "triple gauge" in the forums, the conversion to non-factory gauges has been done before.
Edited by Howie
^^ perfect,
I tried every thing except triple guage,
Will do now
Thanks
Josh
No worries.
As for what gauges fit in there, 2" / 52mm gauges fit in there no problems. Some don't quite look right with the bezel on ( i think autometer might be one of these but don't quote me on that ).
The question about using the factory oil pressure signal - i had a look at the unit last night and there's just a loom going to the back of a sealed unit. I'm guessing one of them is the oil pressure signal and can be tapped in to but i'll have to check my manual to be sure.
Interested in seeing how yours turn out so be sure to post pics mate! :O
Hey Guys,
Cheers
Josh
i have done this before, take a look at the link to my post
http://www.skylinesaustralia.com/forums/in...131154&st=0
Speaking of this my tripple cluster rattles alot and is really annoying for me.
What should i use to put between it and the cars dashboard to get rid of the rattles? Some sort of sound deadener? and where would i get it from?
Use foam weather strips that you would normallly use between door jams. The type that you can peel off on one side to reveal an adhesive.
I use that on anything from the cold air ducts to the gaps around my panels when soundproofing my boot.
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
