Today I was having a little squirt against some dude in a rotary, and my gearbox "locked".
The gear shift came out of 1st alright, but then when I tried to select 2nd at around 6k rpm (roughly), it wouldnt go in. I tried 3rd, that wouldnt work either. I couldnt select ANY gear. I had to roll to a stop and then ram the gear stick into third with my foot on the clutch.
This is the second time it has happened ... first time was on Friday night. I had also just launched on that occassion and was attempting to change into 2nd.
What is causing this?
Any help would be muchly appreciated :P
https://www.sau.com.au/forums/topic/13494-gearbox-locked/
Most likely u have selected 2 gears when attempting to change gears. What happens is the selector gets stuck between the 2 gears, and even thou u can move the shifter around, it wont select anything else. This happened to me and my gearbox locked up. I had to get it reconditioned cos it was stuck and wouldnt come out.
https://www.sau.com.au/forums/topic/13494-gearbox-locked/#findComment-262318
this happened to me at about 150 woudlnt go into 4th. i slowed down till abotu 80 and ramed it in. i tried 5th but it didnt go into that, until i slammed it into 4th then everything was normal. its very strange.
only happned once for me. and if it ever does again it iwll be in the back in the workshop.
https://www.sau.com.au/forums/topic/13494-gearbox-locked/#findComment-262624
it's happened to him twice now - the first time was wierd ... after he pulled over and got the gear in, the shifting was REALLY easy, like it went into gears so much more 'loosely' than how it used to, and currently, does (and it engaging the gears as he tried moving forward and back etc)
off to g/box specialist then! :D
https://www.sau.com.au/forums/topic/13494-gearbox-locked/#findComment-262795
JiMiH
this on sundays cruise? i was behind that RX3(i think), saw u 2 launch then u pulled over into UWA, i thought u wanted to hide after he left big snakeys at 60km/h when he changed into 2nd :P, he was lookin for u after that, couldnt work out where u went. that thing probably did low 12's at least.
my gearbox has also become very 'easy' to shift. its got a c's short shift kit, which always felt very tight (a bit too tight, felt had to use a bit of force esp when cold), i got redline shockproof put in my gearbox about 1-2 months ago, and it's pretty much eliminated any crunches i ever got, changing into 2nd from 1st, especially when it was cold. but just in the last few weeks its become really easy to shift, which is a good thing and no crunches ever now. :) let us know how yours goes.
https://www.sau.com.au/forums/topic/13494-gearbox-locked/#findComment-265664
Originally posted by b005t
this on sundays cruise? i was behind that RX3(i think), saw u 2 launch then u pulled over into UWA, i thought u wanted to hide after he left big snakeys at 60km/h when he changed into 2nd :D, he was lookin for u after that, couldnt work out where u went. that thing probably did low 12's at least.
Chris yeah dude on Sunday haha
why was he looking for me? I was farken pissed about that gearbox I was almost ready to put a for sale sign on my car :bahaha: just kidding :D
fatz: tell me more! what could be wrong with my slave cylinder to cause this? Would be appreciative of the info :)
Cheers guys for your replies :)
https://www.sau.com.au/forums/topic/13494-gearbox-locked/#findComment-269768
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
