Intercooler Set-ups: Pipework
Beef
 Share
  • Replies 50
Posted Images
yeah i was like wtf when i saw his setup...
maybe he turned the core upside down or something...
the reason he Beef did his intercooler piping like that is so that the air
that goes into the throttle body is cool, as it doesnt pass behind the radiator like most kits
which makes the intercooler piping warm/hot. The way he did the pipework is really good.
' date='19 Sep 2006, 09:38 PM' post='2510969']
it might help it a little bit.. but it still passes over the hot engine, heating it up again.
ultimately you want a custom/gtr style plenum that takes the air in the front of the plenum, and doesnt pass over anything warm/hot.
like this..
ever touched a top radiator pipe? the one thats basically touching the intercooler pipe on the photo you posted.....they get farking hot :woot:
I don't think it really makes much difference..the air is travelling pretty quickly...so its not going to get much chance to heat up
Ive seen an R32 do the pipes like that before, very very nice IMO.
Here is a thread from the Stag forum.
http://www.skylinesaustralia.com/forums/in...c=92828&hl=
I would have done it like the guy above, but that way uses a few more pipes etc and would have ended up costing me a fair whack more, as i couldnt retain ANY of the stock piping.
id dare say the rocker covers get a tad hotter than a radiator hose, not to mention a fair bit more surface area.
there is going to be hot parts where ever the piping is routed, but minimising the length/hot points it passes is ultimately going to give you the most power and response. :woot:
but with beefs way it passes over the engine before the cooler and heat transfer via convection (dominant mode of heat transfer) is proportianal to the difference in temps.
so as the hot pipe passes over the engine it doesnt absorb as much heat as the cold pipe going over the engine in the normal setup.
if the air collects the heat on the hot side, it still gets cooled by the intercooler. if it is heated on the cold side, there is not chance for further cooling.
id say the effects would be fairly small, but the theory is there still
yeah, but then it wont cool down to as low a temperature as it passes through the intercooler >_<
either way, its good to see people not taking the standard approach to engine mods..
i was wondering if it had any affect on lag or anything as opposed to the tradtional RB25 intercooler setup.
it seems to use 45 degree bends, and long radius 90 degree bends which could help a bit with air flow, rather than the big U shape the typical kits have.
care to elaborate on that, beef?
well the guy who fabricated this set-up said that the traditional "U" shape set-up had a hell of a lot of bends.... he said he has designed a lot of intercooler set-ups with the straightest possible lines and also with the turbo side entering on the left and right of the cooler to see the effects of both.
This was the best he came up with, it is the straightest lines possible on an RB25 and also the pipe going to the intake is marginally cooler when getting to the intake...
his words "this is the perfect, most straight custom intercooler piping ever created for the rb25" :laugh: ha ha he has a big ego....
but i think its justified
Beef
Hi there this is my setup everything went in really fast,piping ,fmic just had a prick of a time with the high mount manifold ,so i bought a few ss bends off ebay and made the rest myself this car really kicks as i live in the bush dont know what power it has never been dynoed a friend "reckons " it has well over 220rkw but guess only dyno results tell the real powerpost-30197-1158712585.jpgpost-30197-1158712635.jpg
I don't see whats wrong with the pipework going near the radiator, the pipe gets hot but air is pretty bad at absorbing heat, thats why the intercooler is designed to give a large surface area because it needs alot of air passing through it to cool the intake temp down.
Even look at the CPU cooler on your comp, same principal, maximum area (plus a bit of turbulence).
If air was effeceint at absorbing and losing heat we wouldn't need intercoolers, just run a pipe along the front of a car would be all.
Edited by Rudager
Hey Dezz thats the exact kit im after for mine how long did it take you to do and were there any dramas involved? My car is a series 2 as well What did you have to cut out of the front bar?
Cheers
Chris
Hey Dezz
Could you post some pics of your intercooler kit with the bumper on??im thinking of going for that type of kit aswell instead of going for the usual hybrid, chinese piping kits etc etc
Cheers
The pics i posted were the blitz kit on my mates car. We're installing my kit this sunday, so i'll try to take some photos throughout the process and put em up.
Here's a photo with the bar on
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
