  • Replies 50
Posted Images
yeah i was like wtf when i saw his setup...
maybe he turned the core upside down or something...
the reason he Beef did his intercooler piping like that is so that the air
that goes into the throttle body is cool, as it doesnt pass behind the radiator like most kits
which makes the intercooler piping warm/hot. The way he did the pipework is really good.
' date='19 Sep 2006, 09:38 PM' post='2510969']
it might help it a little bit.. but it still passes over the hot engine, heating it up again.
ultimately you want a custom/gtr style plenum that takes the air in the front of the plenum, and doesnt pass over anything warm/hot.
like this..
ever touched a top radiator pipe? the one thats basically touching the intercooler pipe on the photo you posted.....they get farking hot :woot:
I don't think it really makes much difference..the air is travelling pretty quickly...so its not going to get much chance to heat up
Ive seen an R32 do the pipes like that before, very very nice IMO.
Here is a thread from the Stag forum.
http://www.skylinesaustralia.com/forums/in...c=92828&hl=
I would have done it like the guy above, but that way uses a few more pipes etc and would have ended up costing me a fair whack more, as i couldnt retain ANY of the stock piping.
id dare say the rocker covers get a tad hotter than a radiator hose, not to mention a fair bit more surface area.
there is going to be hot parts where ever the piping is routed, but minimising the length/hot points it passes is ultimately going to give you the most power and response. :woot:
but with beefs way it passes over the engine before the cooler and heat transfer via convection (dominant mode of heat transfer) is proportianal to the difference in temps.
so as the hot pipe passes over the engine it doesnt absorb as much heat as the cold pipe going over the engine in the normal setup.
if the air collects the heat on the hot side, it still gets cooled by the intercooler. if it is heated on the cold side, there is not chance for further cooling.
id say the effects would be fairly small, but the theory is there still
yeah, but then it wont cool down to as low a temperature as it passes through the intercooler >_<
either way, its good to see people not taking the standard approach to engine mods..
i was wondering if it had any affect on lag or anything as opposed to the tradtional RB25 intercooler setup.
it seems to use 45 degree bends, and long radius 90 degree bends which could help a bit with air flow, rather than the big U shape the typical kits have.
care to elaborate on that, beef?
well the guy who fabricated this set-up said that the traditional "U" shape set-up had a hell of a lot of bends.... he said he has designed a lot of intercooler set-ups with the straightest possible lines and also with the turbo side entering on the left and right of the cooler to see the effects of both.
This was the best he came up with, it is the straightest lines possible on an RB25 and also the pipe going to the intake is marginally cooler when getting to the intake...
his words "this is the perfect, most straight custom intercooler piping ever created for the rb25" :laugh: ha ha he has a big ego....
but i think its justified
Beef
Hey Dezz thats the exact kit im after for mine how long did it take you to do and were there any dramas involved? My car is a series 2 as well What did you have to cut out of the front bar?
Cheers
Chris
Hi there this is my setup everything went in really fast,piping ,fmic just had a prick of a time with the high mount manifold ,so i bought a few ss bends off ebay and made the rest myself this car really kicks as i live in the bush dont know what power it has never been dynoed a friend "reckons " it has well over 220rkw but guess only dyno results tell the real powerpost-30197-1158712585.jpgpost-30197-1158712635.jpg
I don't see whats wrong with the pipework going near the radiator, the pipe gets hot but air is pretty bad at absorbing heat, thats why the intercooler is designed to give a large surface area because it needs alot of air passing through it to cool the intake temp down.
Even look at the CPU cooler on your comp, same principal, maximum area (plus a bit of turbulence).
If air was effeceint at absorbing and losing heat we wouldn't need intercoolers, just run a pipe along the front of a car would be all.
Edited by Rudager
Hey Dezz
Could you post some pics of your intercooler kit with the bumper on??im thinking of going for that type of kit aswell instead of going for the usual hybrid, chinese piping kits etc etc
Cheers
Cheers
Chris
Hey Dezz
Cheers
The pics i posted were the blitz kit on my mates car. We're installing my kit this sunday, so i'll try to take some photos throughout the process and put em up.
Here's a photo with the bar on
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
