Or anyone else with skills - ive tried and failed. wheels are easy, so is height, and i even made a pretty cool looking trailer out of half a stagea, but i cant do paint for SHIT. You did a decent job on your mums car...
In 4 weeks my car goes in for a paint job, hoping to be having air-ride suspension fitted, and 20" wheels.
(also a brake upgrade, as well as a rough $5k of engine work)
The car is to be a promo car for saikoogarage.
Paint is to be two tone. Standard Ice-Green, up top, but with a bayside blue 1" pinstripe along the bodyline (the groove that goes front to back, above the doorhandles), with a white bottom half which has a light gold pearl through it. Ride height is obviously going to be right down low. Wheels are white, with chrome dish, SIMILAR to wilch's, but instead of fridge-white centres, theyll be same pearl white as the lower half of the car.
Is this paint job do-able in photoshop?? Its just ive spoken to a fair few people, and get many mixed responses about how it will look, so im hoping to see it before i commit to it...
Thats dudes. Hope someone is bored enough to spend 30min or so of there life on it hey... haha if it gets in a mag or something, ill be sure to mention you as being instrumental in the build :-)
https://www.sau.com.au/forums/topic/135012-obnoxsh-haha-pimp-my-ride/
