i got my set including bonnet sticker off ebay, unfortunately cant find the users details but if you keep checking back on ebay they should come up sooner rather than later
Do you happen to know what keywords they were listed as and in what section they were listed. Just so i can check on ebay
Cheers
PM 'AdzMax' that's his black R34 (Vic) looks shmick :)
don't know where he got it done, but he'll know the score
Yeah thanks i know, i took that pic..lol
Nah i spoke to him and am aware there is another member on the forums attempting to make them but i'm impatient :(
  • 3 weeks later...
Hey guys, I've actually just got some of these for my R34. I used a company from the UK if thats any help for you.
The company is http://www.undergroundgraphics.com
They cost in the reqion of about St£100, and you'll also need to supply them with the length of your car and also the colours you want the stripes in. They supply the graphics as three individual colours as this is the best result, but means that they are harder and more expensive to install. however the result is much better.
I'm sure however that there are Graphics Companies down there in Aus. just make sure that they have supplied the graphics before or else you'll need a very good picture of then so they can copy it.
Hope that helps.
John
How much did you pay for it? Do you have more close up side pics?
