Was wondering if anyone can help me get my car started,
Its an R30 skyline with EFI'd L24 engine it in, i seem to be getting pretty good spark - but not sure about the fuel,
I cannot hear the fuel pump when car is on accessaries or start, i also removed the line from the fuel filter (in the engine bay) there was fuel in the filter, but i was thinking fuel should piss out when i turned the key to acc or start? this did not happen..............
Anyone got any suggestions?
https://www.sau.com.au/forums/topic/135033-car-wont-start/
Check relays and fuses, if all ok check power to the fuel pump. All ok probally fuel pump.
https://www.sau.com.au/forums/topic/135033-car-wont-start/#findComment-2513097
Had a similar problem a while ago; It was a dying fuel pump. I extended the life of the pump with a 15" adjustable wrench - just give the pump a tap or 2, and it might jump back to life for a while.
https://www.sau.com.au/forums/topic/135033-car-wont-start/#findComment-2513439
  • 4 weeks later...
I have the exact same problem with my L20ET, and have had many a auto spark look at it whilst straching their heads.. i can tell you that it will either be the ecu (old/dry soldier joints), the relays/fues. The problems that develop with those old ecu's is a strange one because it wont do the smae thing twice.
the ecu just simply wont send any signal to the relays/vaccum sensors (one over next to the left strut) or in my case to the shitty little computer in the boot that apparently controls fuel and boost signals.
good luck.
try resetting the computer by disconnecting the battery for a little while, a good spray in the fuse box with some water dispersent, and kick the ECU in the guts a few time if theat doesn't work
https://www.sau.com.au/forums/topic/135033-car-wont-start/#findComment-2579574
good luck.
Sorry to hijack this thread, but David I don't see you on the Classic Skyline register yet.
But my main question, is your 4 dr a Paul Newman Version or stock HR30, as we are trying to locate a 4dr version, last seen in Qld.
Cheers, D
https://www.sau.com.au/forums/topic/135033-car-wont-start/#findComment-2579724
  • 4 weeks later...
Cheers, D
Checked the fuel pump computer? Mine wouldnt start for 6 months because that damn computer was stuffed.
https://www.sau.com.au/forums/topic/135033-car-wont-start/#findComment-2641640
  • 4 months later...
Cheers, D
I used to live in QLD on the Sunny Coast and took it dow to Brissy and the Goldie a fair bit..
Now i live in Melbourne and still have the car..
I've got an early (year not exact '81-83) 4 door HR30 GT with an L20ET dark blue/black with gold work ewing rims on it.
contact me via email you want to know anything else
[email protected]
https://www.sau.com.au/forums/topic/135033-car-wont-start/#findComment-2957140
Cheers, D
I should be on the classic register, i attached some pics
https://www.sau.com.au/forums/topic/135033-car-wont-start/#findComment-2958985
mine has a computer in the boot that apparently controls the fuel pump and turbo (boost volumes?)
I'm in the same boat, needing a new ECU as mine is getting very tempremental these days.
https://www.sau.com.au/forums/topic/135033-car-wont-start/#findComment-2960077
  • 3 weeks later...
yeh controls fuel.
mate...have you got gas? I dont mean to sound rude but soemtimes fuel gauges can play up if you dnt have much in the tank
https://www.sau.com.au/forums/topic/135033-car-wont-start/#findComment-2999477
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
