ok toying around with the idea of converting a s chassis car to awd using a skyline as a parts car.
starting with the r32 to the r34, what trimlevels of atessa came in each chassis and how did each system work.
i know that in some cars they had active differentials and others mechanical...
a list or some kind enlightenment would be appreciated.
https://www.sau.com.au/forums/topic/135035-atessa-trim-levels/
From my understanding of it all:
The r32 had a slightly different system to the 33 and 34 which i think were the same???(not exactly sure about the), dunnno the exact differences but you can pull the fuse in the 32 and they will run in rwd you can't with the others. What do you mean by trim levels?
The 32 had hydraulicly operated hicas where as 33 and 34 had electrically operated, most people tend to lock this out anyway for a more predictable rear end on the track.
The vspec's had the active lsd, the normals had a loosley setup mechanical one. The vspec's atessa system is also slightly faster and more aggressive somewhere in the region of a reaction time of 1/1000th of a sec instead of the normal 1/100th on non vspec models.
See the following for a brief but (I believe) accurate summary:
http://en.wikipedia.org/wiki/Attesa
http://en.wikipedia.org/wiki/ATTESA_E-TS
it wont matter so much. the only really viable one (cost wise) would be R32 non-vspec. plus it's nicer to be able to pop fuse and be in RWD. also for a conversion the simplest type the better as less things that can go wrong. A-LSD I would steer clear of for your case too. there is nothing wrong with a plain 2 way mech LSD (standard on 32 GTR).
the only way I would really consider this is buying a wrecked 32 GTR so you have access to ALL the bits.
thanks for the input, i thought the r32 gtr would be the best interms of attempting a conversion as it is the most basic of the 3 production chassis.
however i would be doing this conversion to my s14, so a r33 would be best suited as the r33 and s14 share MANY simmilariaties.
if i were to do this i would have one of my local importers cut a car in half and go from there, that way i have access to everything.
a waste of a gtr? perhaps but we arnt lucky enough to be able to import them and actualy own them here stateside.
I've always heard that but never been able to find out why? I know there are some running around on your streets but they are few and far between. What is the actual reason you can't import them and how have those few got around that?
yes there are a few running round here but it basicaly comes down to improper dot approval.
motorex who was the only registered importer for skylines falsifided test data to get cars into the us, they only crash tested the r33 but not the 34 or 32...this eventualy placed the r32 and r34 on the 'never can be legalized' list and if a car comes in an is seized by customs, say bye bye.
there is alot more to it than just that but it is alengthy story, it honesly involves scandal, crooks and dishonest shops; iirc if you go onto skylinesdownunder in the us section there is a large thread about what happened and why it happened.
there are ways of sneaking a car into the us and getting it registerd but it is tough to do.
hmmm sounds like it comes down to basically gay reasons. So a car has to undergo actual crash testing there before it can be able to be imported? How gay.... Can you import them for track use etc?
p.s. sorry to hijack your thread :)
Move to canada EH? they have 15 year old rustbucket R32's running around cheap as chips. Not exactly V-Specs, but if you live in the US you can't be picky.
Are you on ZT forums? a bloke in the US recently posted some build pics of his S14 where they had just put the front driveshafts and linkages on an S14 off an R32 GTR.
If its not you, and you aren't on ZT, then I'll see if I can find the pics for you.
no im not on zt, what is it exactly?
as far as i know there hasnt been a complete conversion done in the english speaking world, im sure the japanese shops have done it but no one here stateside that i know of has a _working_ attesa car.
i have seen a s13 coupe converted to a locked awd using a gts-4 drivetrain, but it was constant 50/50...not ideal.
THe guy who's doin the conversion I was talkin about is Geoff Raicer, he's from AZ or NJ. Works for Full Race Motorsports (www.full-race.com). They sucessfully fitted the full R32 GTR front subframe onto the S14 a couple of months ago.
Maybe contact them for more details? Geoff's email is geoff (AT) full-race.com
some build pics:
yeah... we're sorta lucky we don't drive on the wrong side of the road like the americans and our local manufacturers don't have a vicegrip on the nuts of governmental policy. That's why I worry when we start making free trade agreements with Bush's regiment and they start introducing bullshit restrictions on us.
You can buy an R32 GTR and have it on the road for about USD 10k these days... and an R33 GTR for about USD 20k... instead of messing around with silvias. We got it good over here.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
