Hi All,
Just wondering what u guys think of the quote and if there are any places around that could possilby do a better price. Also wondering what kind of improvements are noticed with a decent exhaust. Thanks
A split dump pipe is $600 fitted
A 5" ballistic cat with 3" pipe size is $500 fitted
A 3" system is $580 fitted + tip.
https://www.sau.com.au/forums/topic/135043-exhaust-for-r33-96-sii/
sounds a bit much to me. sure it may be worth it for the stuff they are using (possibly) but there are systems out there much cheaper. full x-force turbo back 3" in stainless stell for $970 from UAS. that doesn't include fitting, but you could do it yourself. would take about half an hour.
Hey mate,
Try x-force 3 inch turbo back exhuast. U can get for 800 (mild steel) or so. Good performance at good price. check it out at www.Justjap.com
Just search x-force n you'll see comments from other sau memebers who have purchased this product.
Edited by shorty_01
i run the mild steel 3.5" cat back system, with 3" x-force cat, ebay dump, and some front pipe that was already on the car. very happy with it.
hey sorry to go off topic here but im getting the same setup installed tomorrow, is the 3.5" loud? kinda worried about that they had no 3" avialable hehe.
as for the main topic, the prices sound really steep. shop around and like others have said eBay is your friend! good stuff off there. Just Jap do 3.5" mild steel turbo back exhaust minus the canon for $599. then just get a twin pipe muffler off ebay for $100 and ur set.
Not sure about the dump pipe, but the rest sounds like the going rate for a custom exhaust. Good choice with the 3" pipe any bigger you start to get lag, even a 4" inch cat will do the job might be cheaper than the 5".
Check out C.E.S exhaust just type it in google, they have the best dump pipes for skylines.
If you are running a stock exhaust, you will hear and feel the difference you will like it.
Edited by subzeroR33
how does adding a bigger exhaust create lag?
i don't find the exhaust too loud. the rear muffler is only 3", but i have a mate with the full x-force turbo back (3" front, dump and cat, then 3.5" cat back) and it isn't really any louder. it sounds sweet at full noise. burbles a little on deceleration though.
Im not an expert but i think it has to do with back pressure so i was told, from experience with my car i had a 3.5" exhaust with a 5" tip hks cannon, the car makes 330 rwkw and it did have lag. The turbo didnt cut in til 4000rpm.
Changed it to a 3" pipe and smaller cannon, it feels more responsive quieter and the turbo cuts in at 3500rpm.
madd why does your exaust change size 3 times from turbo to tip i would have thaught keeping things the one size all the way through would be best
it may creat a little dead spot running a bigger exhaust but it till make more power everywere even tho you can feel a little delay stomping it with the stock turbo from low revs.. a smaller exhaust may creat back pressure and spool up quicker how ever it will be making far less power.. for instance a mates r32 was seeing 14psi by 2400rpm only made 126rwkw!!! with the stock turbo and a FULL 3inch turbo back exhaust (cat converter had fused together)
after we replaced the cat with a brand newy the car felt completely different to drive in every way.. havent put it back on the dyno yet but am looking at doin that sometime next week..
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
