well guys....found a cheaper alternative, 350 cheaper. I got it dyno'd before and after. completely stock at 144.5rwkw to 169.0rwkw. Very happy with the result, and now on my way to 200rwkw.
Im not an expert but i think it has to do with back pressure so i was told, from experience with my car i had a 3.5" exhaust with a 5" tip hks cannon, the car makes 330 rwkw and it did have lag. The turbo didnt cut in til 4000rpm.
Changed it to a 3" pipe and smaller cannon, it feels more responsive quieter and the turbo cuts in at 3500rpm.
wrong wrong wrong
Turbo cars = bigger exhaust the better
There was something else wrong with your setup, it wasnt exhaust related, unless said exhaust had poor bends etc.
Hence im going twin ~2.75" for my setup and only after 300-330rwkw
let's just say i removed the cat but still had the cannon out the back (making the car seem normal and safe) but in true fact had a GAP in the exhaust so all id have was an aftermarket dump/front pipe then an empty space then the rest of the exhaust.. would i have extreme spooling and extreme kw increase?.. (apart from the loud noise)
Do you mean putting a replacement pipe in where the cat was?
there will be a minor gain possibly
ok let me re-explain... complete exhaust system is taken off... all that is left is the dump pipe and front pipe safely bolted on the bottom of the car
The car will be so illegal it wouldnt be funny.
Your NOT allowed to run a car with an exhaust that finishes that soon, it has to be past the rear pillar or whatever to pass the most basic exhaust requirements
Plus it will be that loud you wont get far without half the neighbourhood reporting you.
So dont expect "extreme spool, power increase"... expect the "extreme ass kick" local authorities will give you for being stupid
trust me... in perth we go for car cruizes all night and no1 looks 2wice to try an " extreme ass kick " on us.. im just curious if it would have an overall performance increase
i've been to perth actually and i saw a different view :(
Funny eh?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
