Haxorz Posted September 21, 2006 Author Share Posted September 21, 2006 11psi would only be safely achieveable with a FMIC... Just FYI my tuner today said he reckons 12psi without a cooler and 14psi with a cooler is OK with the stock GTt turbo, so I guess what I said above was NQR. Looks like its my ignition system that's now robbing me of power (i.e. and allowing to only run 9psi). Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2515556 Share on other sites More sharing options...
Abo Bob Posted September 21, 2006 Share Posted September 21, 2006 Well I think you should find yourself a different tuner. 14psi with stock turbo is just asking for trouble. I guess he's hoping you blow it and then go back to him to install a new turbo. Extremely dodgy advice there. To answer your previous question, I noticed no heat soak. Also the tune was done off the car. Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2516321 Share on other sites More sharing options...
Haxorz Posted September 21, 2006 Author Share Posted September 21, 2006 No noticable heat soak? I take it you still don't have a FMIC...? After that comment I'm really leaning against one. Maybe just fix my dodgy coil/ignition issue, get a Power FC installed and tuned and then re-asses. I know if I go a FMIC I'll cop another tune, but from your comment I can't really see the point (for me - as I just do the odd squirt and don't need consistent performance)? Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2516594 Share on other sites More sharing options...
GreddyGo Posted September 21, 2006 Share Posted September 21, 2006 With a PFC does it interfere with the Airbag and things like that? I Know they have a seperate module but they still communicate with the ECU, Cheers Josh Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2517170 Share on other sites More sharing options...
Haxorz Posted September 26, 2006 Author Share Posted September 26, 2006 Update - just picked up a Power FC. Getting installed and tuned tomorrow. Will do a little before and after write up with my R34 + full exhaust + Power FC with stock cooler. I'll be happy if I get 190rwkw, but I'm secretly hoping for 200rwkw. Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2530296 Share on other sites More sharing options...
nuffsaid Posted September 26, 2006 Share Posted September 26, 2006 Cool thanks that would be v. good! Interested to know how the car does as I might go for that option (same mods) A write up on driveability, comfort, performance, fuel economy, response, and any problems would be very helpful Cheers Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2530314 Share on other sites More sharing options...
Haxorz Posted September 26, 2006 Author Share Posted September 26, 2006 It's all happening so fast! I really need to take note tonight of the 'before' picture. What do we want to know? I can think of: 1. Boost (when it comes on, how it holds without an EBC). 2. Fuel economy 3. Driveablity 4. Idle / cold start 5. Power curve (low down, mid range especially) 6. Responsiveness 7. Heat soak on stock intercooler 8. Tuner review 9. Dyno graphs (before and after) Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2530444 Share on other sites More sharing options...
Bass Junky Posted September 26, 2006 Share Posted September 26, 2006 How about taking a 20 x 20 grid of your before and after ignition and injection numbers. I've done that and it's interesting to compare your before and after results. Make sure your tuner does ALL ranges, not just WOT. The full tune should take a fair while on the dyno. Don't be afraid to tell him to lean out the cruise to about 15:1 and make sure it's lean as buggery so you can get great fuel economy. Make sure he tunes the 1-2-3-4-5-6 cylinders to be a little richer at cylinder 6 than at 1. But yeah, doing a 20x20 grab of your numbers is cool, Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2530546 Share on other sites More sharing options...
Haxorz Posted September 26, 2006 Author Share Posted September 26, 2006 Good advice. I will be speaking to him about that, I don't want a high max power with crap fuel economy. The tune will take 2 days, as the tuner said in order to do the cold start 100% you need to do a real life cold start. He said he could get it 99% right if it were just a 1 day tune. Leaning out the cruise sounds like a great idea. I'm hoping he'll be doing that anyway, but it doens't hurt to re-iterate it. It's getting done by Ben @ Racepace, who has come highly recommended and has done some great work with friends cars. Oooooohhhh so excited! :PBJ: Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2530579 Share on other sites More sharing options...
Bass Junky Posted September 26, 2006 Share Posted September 26, 2006 If you are getting it done by Benno then you will not have a single problem in the world. Put in it the fuel you normally use. Drop it off, don't call him, he'll call you. He'll tune it very very well, he's the best. He's the only one who tunes mine. Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2530599 Share on other sites More sharing options...
Bass Junky Posted September 26, 2006 Share Posted September 26, 2006 Actually tell him to put as much carbon in the tune as he did with my car. This amount is virtually none at all! He'll know what I'm talking about. Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2530611 Share on other sites More sharing options...
Haxorz Posted September 26, 2006 Author Share Posted September 26, 2006 (edited) Hahaha, that's good - cause I have no idea what you're on about! I take it your happy with Ben's tune? Edit: whoops, missed your previous post. Great to hear and thanks for the info. Edited September 26, 2006 by McCracken Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2530615 Share on other sites More sharing options...
5ky Posted September 26, 2006 Share Posted September 26, 2006 so adding a turbo back exhaust and air filter, it raised the stock boost to 12psi? and its bad for the car? and where did u buy the larger restrictor from? i currently have a pod and jap catback and my boost raised to 0.8-0.9 bar which equals 12psi already, i cant imagine how much it would go up when i get a dump and front... Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2531310 Share on other sites More sharing options...
Haxorz Posted September 26, 2006 Author Share Posted September 26, 2006 From what I've read around here, on an R34, stock turbo and cooler 12psi is pushing it. I'd have mine at say 10psi max if you want some reliability. Yes, the exhaust made the car boost 'too much' and it started to misfire. A performance garage put the restrictor in. Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2531500 Share on other sites More sharing options...
5ky Posted September 26, 2006 Share Posted September 26, 2006 the restrictor was put inside that hose that goes from the actuator and to the intercooler piping nipple right? Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2531582 Share on other sites More sharing options...
chrissso Posted September 26, 2006 Share Posted September 26, 2006 Hey Mcracken, get your boost set to 10-11psi. This should be low enough to be considered just below the danger limit. Of course, the choice is totally yours. You maybe happy with 9psi. The retune might get rid of the dip. Get him to check the fuel pressure on full boost..If a bit low, then back to 9psi for you I'm afraid... and a need for a bigger fuel pump! Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2531605 Share on other sites More sharing options...
5ky Posted September 26, 2006 Share Posted September 26, 2006 where should 9psi needle sit at on the stock boost gauge? 0.6 bar? Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2531625 Share on other sites More sharing options...
Haxorz Posted September 26, 2006 Author Share Posted September 26, 2006 Yes. 1 bar = 14.7 psi, so around 0.61. Yeah, hopefully 10psi after tune, all going well. Not 100% sure of the restrictor location. I thought it was to the wastegate solenoid or acutator spring or something. I really can't rememeber, I have a novated lease now so I leave all that stuff to the workshops now. Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2531694 Share on other sites More sharing options...
Bass Junky Posted September 27, 2006 Share Posted September 27, 2006 I'm looking forward to your graphs from Benno and his tune so I can compare it to my original PFC tune done by somebody else. Make sure to post it, and ask him for a graph that goes up to 210 kph on the x axis. Make it easier for us to compare. BASS OUT Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2532399 Share on other sites More sharing options...
Munna1 Posted September 27, 2006 Share Posted September 27, 2006 Get yourself a R32 GTSTwastegate actuator you will be running 10 to 11 psi and hold boost perfectly. keep the stock cooler and buy a SAFC or power FC 190rwkw should be acheived cheers Link to comment https://www.sau.com.au/forums/topic/135049-r34-gtt-full-exhaust-mod-1647rwkw/page/2/#findComment-2533700 Share on other sites More sharing options...
