Hi people
i can pick up a red top rb20 for a good price with a little bit of work done to it and i was wondering if i do get this engine can i use all my parts from the silver top engine like manifold gt30 turbo coil packs injectors microtech ect ect i basically want to make sure i can put this engine in and everything plugs into the right places and will fire up. Do i have to change the loom or anything like that??
Also what is the difference between these engines like the different power output???
Cheers
anthony
Hi people
Cheers
anthony
dont know about ur first question but im interested also
the other question -
red tops less stock power ~10kw or something
red tops more low down torque (not much difference though)
once uv started to modify the redtop - the differences wont matter.
The red one's a NICS engine and the silver one's a Plazma engine from memory. Altho the series 1 cefiro's had silver top NICS engines (fun fun fun) :ermm:
They use different AFMs, alternators and ECU plugs, but its not that hard to modify em to work with the silvertop ancillaries.
Red top is the old NICS. 12 port intake, really piss fart breathless turbo and shocking ECU mapping. Also has butterfly plates in the intake to control/limit flow at certain points, something with more stable power delivery or somethin, can't remember that well off the top of my head. But yea, fix the ECU up, change the turbo, get rid of the butterfly plates and clean it up a little and the red top will be fine.
oh and yes i think the wiring is different. I can't recall about the internals, but i know for a fact that the head/bottom ends aren't interchangable with the two RB20's, different bolt pattern, i think.
Ok but will the loom from my silver top plug into the red top now this engine is an ex under 2lt sports sedan engine so i would be asuming that the butterfly's would already be taken out of it. Everything else i want to change over from my motor that being coil packs (split fires) injectors, gt30turbo engine management ect ect.
So how much power did these engines make i.e the under 2lt sports sedans if anyone knows and do you think that the engine would have any internal work done to it?? the guy i'm buying it off said that the engine looks to be ported which is a good thing as they have f*^$k all breathing. However he does not know the condition of the motor because he has never seen it running but like i said it's damn cheap
any info would be great?
Cheers
anthony
The butterflies are used for variable inlet runner lengths. They tend to eventually jam in one position so that the car runs shit at one end of the rev range and shit hot at the other.
The manifolds are different to the ECCS engines.
If this particular engine has a turbo, then it can't be an under 2litres sports sedan; turbos have a 1.7 capacity fudge-factor, so it's equivalent to 3.4 litres.
NICS(red top) cams have more lift on the exhaust side, silvertop inlet cam has slightly more duration. Injectors are in different position. Silvertop ECCS has a better flowing intake. The butterflies on the NICS redtop open at around 3800rpm, like i mentioned before, a power thing, so you don't want them stuffed up (get rid of them alltogether).
I'm not too sure about the internals, you'd have to take them out and compare them side by side.
I can try and dig up more info on the NICS butterfly system and ECU if you need it.
NOTE: there are TWO versions of the red top RB20, a red top NICS and red top ECCS, so DO NOT confuse red top ECCS with silvertop ECCS. Differences between redtop NICS and ECCS are: ECCS redtop head aint as good flowing, has SLIGHTLY better turbo than NICS, slightly better ecu and inlet (still 12 port, still has butterflies i think)
There are 2 types of red top RB20DET:
NICS - already discussed here, fitted to some Jap spec R31's from 1986 to about mid-1987, ~140kW at the flywheel.
ECCS - fitted to some Jap spec R31's (1987 ->), that is it replaced the NICS version. ~150kW at the flywheel. Manifold arrangement is very similar to the R32 type (no variable inlet), but other detail differences included non-BB turbo.
Red top ECCS still has 12 port intake, better flowing than the NICS one though
hey mate
the eccs redtop is the better of the lot (NICS, silvertop) that is if u change the ecu aftermarket or remap, port the head and match the manifold, get rid of the butterflies, u can port these heads/manifolds more than the silvertops, the cams are more aggressive, and the bottom end is roughly the same although it is fairly strong and can take a beating
silvertop 6 port manifold can not go on to redtop 12 port (ECCS or NICS) as the ports dont match and coolant gallery closest to the radiator doesnt line up right
head and bottom ends arent interchangeable different bolt patterns between the silvertop and redtops
loom will connect in some spots, u can run the ignitor and coil packs, CAS is different and there are 3 different redtop ones, but u can use a silvertop CAS as it bolts up, injectors are smaller on the redtops
anyway that is all i can think of, the many let downs on the redtops were the ecu, port design, inlet manifold. but if u modify them then they go fairly well, but it is hard to get gaskets now!
i preferred my redtop over the 20/30det and the 25/30det, yea the 20/30det and 25/30det had the power and torque but they didnt have the reliablity and the ability to be thrashed or worked hard like the good old rb20, now the redtop is back in my VL plus its a gts-r motor so i didnt want to get rid of it as these are rare
sorry to hijack but...
what is all this talk about butterfly valves in the intake?!?!?
i have a red top NICS and the only butterfly valve in the intake i can see is the actual throttle body lever...
are these valves after the throttle body in the intake manifold??
I did a big write up on the differences years ago...
The red top does have a different bolt pattern to the silver top. Yes there are 3 rb20 motors. However all the HR31's only ever came from factory with red top engines. If you see a HR31 with a silver top this motor was swaped out of a R32.
Silvertop offers the most refined and highest power output from factory. Also parts are very easy to come by...
Redtop NICS - 140kw ish at flywheel, 12 post plenium with vacum operated butterflys.
Redtop ECCS - 150kw ish at flywheel, 6 port plenium.
Silvertop ECCS - 160kw ish at flywheel, 6 port plenium.
Easy way to identify the 2 red tops is by the runners under the main plenium gallery, or of course by the big badge ontop of the plenium... :laugh:
I used to have 2 HR31's both came with Redtop NICS engines as standard. I believe that this engine was a huge nightmare as my first 31 spent more time broken then working. As parts are almost impossible to get.
I would always choose the silver top ECCS engine over any other Rb20 simply do to parts and aviablility of aftermarket stuff.
Give you a story. My first HR31 GTS'X had an issue one day which i had no idea how to fix. I assumed it was either an AFM or a CAS. However i didnt know anyone with a red top enigne to swap out and test. So i ended up getting it tested by petro-jet and yes the afm was stuffed.
Priced around the the cheapest i could get a new AFM for the red top was $690. Plus i had to pay petrojet for their labour.
I had no option to buy second hand, cause there simply was not any aviable second hand.
Second hand parts for a silver top and that afm would have cost me $50-80...
This reason alone should help make your decision easier.
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
