Is just the AFM your replacing. As said there is the wiring change it appears you have caterd for that.
Do you have an after market ECU that caters for the AFM being changed? (Power FC etc..)
Are you changing from an air box to a POD. If so do you have the brackets and extension pipe also?
Relatively easy.
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2512828
Relatively easy.
Yep i have the power fc, i thought i was replacing the standard afm wit hthe Z32, so whats this pipping i need?
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2512844
Your Power FC caters for the change in AFM's as one of the menu options.
Small extension pipe is only required if your changing from a an air box to a pod filter. Some do this when changing AFM's. As the Z32 AFM is a different size to your existing AFM the plumbing needs to different.
I bought an Apexi kit so all I needed came in the box. POD's, ruber Plumbing including ext pipes, wiring, brackets.
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2512955
I'd guess your pod wont fit if you insert the Z32 due to size difference. That applies to a GTR. Cant be absolutely cert for a 33.
As you say - suck it an see. 5 minutes max to get an answer.
Good name change too.
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2512979
R33 series II and Z32 are the same size 80mm. You should be able to just throw the old one over the shoulder and insert the new one without even looking up...........too easy.
As far as I know they are pretty much a direct replacement. But you will need to hook the four wires up in correct sequence. Let me know if you need a wire code over each one and I'll look at mine.
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2513982
I didn't read this till i got to work, I'll look and let you know.
My wires at the Z32 are all black, but across the top there is [from memory] 6 positions marked A,B,C,D,E,F and they join [from memory], black earth, a white/blue, a black/white, and another one I can't remember. Positions A and F are vacant. Please don't use this because none of it is in order, it IS NOT THE CODE. I'll check and get back to you as I've said.
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2514870
Try this:
B - Orange/Blue trace
C - Earth
D - White/Blue trace
E - Black/white trace
looking at back of the plug [so pod is on your left and trubo on your right] B is the first wire out, and E is the fourth wire out.
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2515715
:( My bad - know mine were 65mm. 33's got it easy then.
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2521301
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
