Is just the AFM your replacing. As said there is the wiring change it appears you have caterd for that.
Do you have an after market ECU that caters for the AFM being changed? (Power FC etc..)
Are you changing from an air box to a POD. If so do you have the brackets and extension pipe also?
Relatively easy.
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2512828
Relatively easy.
Yep i have the power fc, i thought i was replacing the standard afm wit hthe Z32, so whats this pipping i need?
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2512844
Your Power FC caters for the change in AFM's as one of the menu options.
Small extension pipe is only required if your changing from a an air box to a pod filter. Some do this when changing AFM's. As the Z32 AFM is a different size to your existing AFM the plumbing needs to different.
I bought an Apexi kit so all I needed came in the box. POD's, ruber Plumbing including ext pipes, wiring, brackets.
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2512955
I'd guess your pod wont fit if you insert the Z32 due to size difference. That applies to a GTR. Cant be absolutely cert for a 33.
As you say - suck it an see. 5 minutes max to get an answer.
Good name change too.
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2512979
R33 series II and Z32 are the same size 80mm. You should be able to just throw the old one over the shoulder and insert the new one without even looking up...........too easy.
As far as I know they are pretty much a direct replacement. But you will need to hook the four wires up in correct sequence. Let me know if you need a wire code over each one and I'll look at mine.
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2513982
I didn't read this till i got to work, I'll look and let you know.
My wires at the Z32 are all black, but across the top there is [from memory] 6 positions marked A,B,C,D,E,F and they join [from memory], black earth, a white/blue, a black/white, and another one I can't remember. Positions A and F are vacant. Please don't use this because none of it is in order, it IS NOT THE CODE. I'll check and get back to you as I've said.
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2514870
Try this:
B - Orange/Blue trace
C - Earth
D - White/Blue trace
E - Black/white trace
looking at back of the plug [so pod is on your left and trubo on your right] B is the first wire out, and E is the fourth wire out.
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2515715
:( My bad - know mine were 65mm. 33's got it easy then.
https://www.sau.com.au/forums/topic/135084-fitting-afm/#findComment-2521301
