nsta Posted September 20, 2006 Share Posted September 20, 2006 Hey guys as the title suggest, im about to put alot of money into my motor, and was wondering the best way to confirm its healthy to start off with, or else i may end up having huge problems in the near future...... whats the sure way of knowing a good motor to start with??? Link to comment https://www.sau.com.au/forums/topic/135166-how-to-check-if-motor-healthy/ Share on other sites More sharing options...
Kennedy Posted September 20, 2006 Share Posted September 20, 2006 Dyno. Compression test. Link to comment https://www.sau.com.au/forums/topic/135166-how-to-check-if-motor-healthy/#findComment-2513386 Share on other sites More sharing options...
mad082 Posted September 20, 2006 Share Posted September 20, 2006 a compression test will tell if it is going to be a good strong motor, but there is no way to be sure of if there is any faulty parts. Link to comment https://www.sau.com.au/forums/topic/135166-how-to-check-if-motor-healthy/#findComment-2513535 Share on other sites More sharing options...
govich Posted September 20, 2006 Share Posted September 20, 2006 Rebuild it yourself with proper parts. Link to comment https://www.sau.com.au/forums/topic/135166-how-to-check-if-motor-healthy/#findComment-2513562 Share on other sites More sharing options...
mad082 Posted September 20, 2006 Share Posted September 20, 2006 even if you build it yourself with proper parts there is always a small chance one of the parts you put in might have a weak spot, or a fault you can't see. it is just something that can happen, no matter how much you spend. not much you can do about it. Link to comment https://www.sau.com.au/forums/topic/135166-how-to-check-if-motor-healthy/#findComment-2513592 Share on other sites More sharing options...
NicsR33 Posted September 21, 2006 Share Posted September 21, 2006 check the spark plugs, probably the easiest test u can do in the garage. if their black, get ur car some nicorette patches. Link to comment https://www.sau.com.au/forums/topic/135166-how-to-check-if-motor-healthy/#findComment-2517279 Share on other sites More sharing options...
chrissso Posted September 21, 2006 Share Posted September 21, 2006 (edited) Leak down test? It's like a compression test, but with more depth to fault finding. Have a mechanic check over it. They know stuff about cars and shit, heh heh. As for faulty parts, well, you get what you pay for. Part companies with a good reputation probably didn't get them by accident. I'm sure that reputable companies utilize technology such as ultrasound and x-ray to see where you can't, before selling you the product. And cars are like chicks, cost money. Edit:- BTW what are you planing to do? If you are upgrading the bolt-on bits, then I would definalty go and talk to a mechanic as a lot of money spent on the inside of you engine might be a set back, but might give you less heart ache in the end. Edited September 21, 2006 by chrissso Link to comment https://www.sau.com.au/forums/topic/135166-how-to-check-if-motor-healthy/#findComment-2517524 Share on other sites More sharing options...
GreddyGo Posted September 21, 2006 Share Posted September 21, 2006 Dyno, Compression test and a leak down, Plus a good look over for any oil leaks. Cheers Josh Link to comment https://www.sau.com.au/forums/topic/135166-how-to-check-if-motor-healthy/#findComment-2517629 Share on other sites More sharing options...
