Did the old poke the curb with my diff trick, still not 100% as to whether it's diff or sump (jacking it up asap) however i'm wondering where to go if I have done the dirty on the diff. Car already has a 2 way cusco in the rear and i'm wondering if aftermarket diffs or later model front diffs are worth investigating.
https://www.sau.com.au/forums/topic/135167-r32-front-diff-questio/
You can't just fit a diff from any old model. The ratios MUST match front and rear.
If your crown wheel and pinion are still OK, then you might find a new centre to mount them to.
Failing that, you could slip me a few $$ for the front diff that came out of mine when I changed to Stagea diffs both ends.
I have a good condition front lsd out of a r32gtr.
PM me if you are interested
Front LSD?
That must be aftermarket.....
I have a normal OEM one for sale, straight out of a working street car, but its not LSD
Cheers for the responses guys :( I was under the impression the front diff was viscous or something but I've never actually bothered to find out for sure. Looking into your items now, will let you know after the car has been jacked up.
    • The way they do the test you would be very lucky to ever hit any cell that isn't aiming at 14.7 This was my result... Really not sure what's going on there!
    • I have a projecta one.  A proper trickle charger can be left attached 24x7, that's what the trickle bit is about.
    • With an electronic boost controller, there are settings available to limit overboost.
    • Ah ok, my tuner did adjust something on the percentage cycle on the boost controller, instead of running at 40% the tuner put it on 20% to compensate for the overboost, can't remember what it was. Not duty cycle don't think, and told me if it keeps overboosting, it's going to be something else. I think he mentioned the turbo actuator.
    • Which trickle charger does everyone use? I'm going on holidays in the future, and last time it was left for a couple weeks off twice per time, and don't want to keep doing it to damage my battery so looking to have something hooked up to the battery which connected to the car, as I need to keep my immobiliser system on. If the battery goes flat it will mess up my security system (already happened once) I was looking at the following, so can have someone turn it on every couple of days and run it overnight then turn it off)   https://www.supercheapauto.com.au/p/noco-noco-genius-5-battery-charger-6v-12v-5-amp/648987.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=1   https://www.supercheapauto.com.au/p/century-century-cc1206-xli-12v-1-3-6a-9-stage-battery-charger/693006.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=30   though these don't say anything about trickle charging, don't want it to overcharge the battery.
