Dont actually know whats cause this, but ill explain whats been done since having it.I think the car was at its peak when it was stock with a pod + 3" exhaust (no cat)
Then a few things went in.......
265 r 235 f tyres with heavy wheels
fmic
removed cold air box to fit cooler, and never placed back in(long story)
gapped sparkies to .5-.6mm as i was getting alot of missing and couldnt increase boost (this may be a big factor?)
bought the sau boost tap and set to .8bar atm
put in a split dump pipe
i feel a combination of the too low gapping of the sparkies, and the big heavy wheel/tyr combo over stock is causing me too have made the big loss.
Is it right for my car to be running rich at this level w/o tune?how can you generally tell if your car is running rich, i most definitely think mine is.
What would you guys reccomend me do to fix my loss?
Thats what i was thinking aswell, may just replace my sparkies, whats sparkies would you reccomend?may just be that theyve gotten weak over time, car has done lots of k's now. I have a Split Dump into a 3" exhaust the whole way. The guys definitely got rid of the missing problem and thus let me increase the boost, but how much have i lost in the process.
How low should the sparkies go when gapped on a failry stockish car like mine?..... 0.8mm?
by having 265 tyres on the rear you have added (depending on the tre size you had on there before hand) up to 120mm of extra tread on the rear, plus between 20 and 40mm of tread on the front. that is a fair bit of resistance.
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
