Why is it not ok to connect a head unit using a loom converter and just use the factory earth through the loom?
Is it really necessary to earth the head unit directly to the chassis?
Does this remove alternator noise not associated with the RCA's positioning?
Does an apexi super grounding system help to eliminate alternator noise?
A small 10cm long capacitor used inline with the power to my amp reduced the spark plug noise by 1/2 but did not completely eliminate it. Would getting one of those giant 30cm long lightning stick capacitors work for me? My battery is in the engine bay, does adding an extra battery in the boot in the way of the power to the amp help?
https://www.sau.com.au/forums/topic/135184-earthing-the-head-unit/
I too am interested in this.
The guy who installed my system is asking for a day to try and get the noise out of it (free of charge - warranty) - and i simply cannot afford a whole day without my car at the moment (bloody work...).
Edited by nsanity
hi, when you get hums or whine noises that you hear from car audio systems, it is caused by electrical interference. most good head unit should not emits any of this audible noise. by saying that, your car's electrical system can also be the problem, old components may create a fault or picked up some sort of interference and this is put straight back through the car's power lines powering your head unit.
Old and tired batteries can cause this problem also.
a good car audio installer will use your factory wiring looms, why? because these cables are dedicated for your sound system and hence your head unit is not crossed wired to anything eles. also solder all contacts and heatshrink/taped all bare wires as it can easily pick up interference from current running through other wires.
noise suppressor can sometimes help and you can get them from Jaycar
i dont know if someone has mentioned it, but making sure your RCA's are running NOWHERE NEAR your power wires for amps and alike is vital. The best way is to run them down opposite sides of the car. Good quality RCA cables reduce alternator whine too as they're generally better shielded.
actually if you use twisted pair leads it does help for noise rejection. the car is a noisey car unfortunately and what may work for one may not work on another.
I had this noise too, found that my RCA wires from the H/U to my amp in the boot was running too close to the earth wire coming from the battery to ground!!! just rerouted them away from the ground wire and noise gone.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
