That cop you spoke to sounds pretty decent and he gave you some good info.
Do what we already told you. You'll be right. Pray to the Mik and Jerry gods if it makes you feel better. Don't forget there is often a little bit of luck in these things and it can go both ways. Roll the dice, be honest and do your best.
  • Replies 41
You will not have to pay the officers costs, only court costs if you loose ( very little like $50-60)but if you win they DON'T pay costs either .
I wish you luck but if you don't have a good lawyer, don't even think of pleading not guilty .
The cops will lie to get you convicted, I have been there and done that several times over the years ( and won every time ).
A good one that comes to memory, cop books me for not wearing a seat belt . I was stopped at the lights at the time, did a right hand turn and then stopped about 2 mtrs from the corner . Got out of my van and walked across the road, cop stops his car behind my van, walks up to me and says: "You wasn't wearing your seatbelt", I said you are right I wasn't but the current law doesn't require me to wear one when I travel under 40 kmh because my job requires me to stop often. He said to me you must have it on even if you are stopped unless the handrake is on and engine off.
When in court under cross examination and under OATH he said i was traveling at 60 kmh when he spotted me . When my lawyer asked him "how fast did you go to catch up with him" his reply 80 kmh .
I did my homework as always so I won the case but it just goes to show you the extent they will go to prove their point .
Risking going to jail !!!
I wish you luck again and let us know how you go, if you win let me know and I'll get some publicity for you in the print media, radio and TV. This is the only thing that scares them ( the ones high up )..
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
