Originally posted by hungry6
by far the best of all the aftermarket japanese computer i've used including power fc!!!!
I'm no expert on ecu's, but wouldn't the power fc be better, just for the fact that its adjustable.
also i've heard that with the mines ecu it can be sent back to mines if you change your mods and they ajust it accordingly, is this true??
https://www.sau.com.au/forums/topic/13524-mines-computer/#findComment-264380
there are no tuners in Aus that can use/adjust the MINES ecu's and therefore if you make a mod, then the ecu must be sent back to MINES JAPAN and they will reprogram it and include the mod you have made.. but just say that you got a nw intercooler from Mick Metalcraft or some other Aussie brand not known over there..
they can't adjust it for that because when they make adjustments, it's like ticking off a shopping list.. eg.. new upgrade to intercooler - HKS, tick..
so I don't know how usefull these are here in aus if you are going to make other mods then what you already have..
https://www.sau.com.au/forums/topic/13524-mines-computer/#findComment-265663
yeah, like everybody else says.. .mines is pretty specialised - it is fine for japan.. but its like the whole ECU has to be reprogrammed to exact specs using Mines equipment.
I'd go for a more local-friendly ECU.. powerFC, wolf3d, microtech, motech, and probably a couple of others.
https://www.sau.com.au/forums/topic/13524-mines-computer/#findComment-266475
  • 5 years later...
Im about to buy R34 GTT and the one Im looking has Mine's ECU. I wonder if that will be any good for performance and reliability or just a headache since tuner will tell me that he s got no idea how to adjust or even check the ECU because its something they r not used to...
So Im afraid of getting the car with Mines ECU and getting ripped off. In case it malfuncitoins and not working what do I do? Worries worries because I have "no idea about Mines ECU"
https://www.sau.com.au/forums/topic/13524-mines-computer/#findComment-3814784
Buy a factory ECU then piggy back it. Negotiate price to free up cash to include this stuff. :)
https://www.sau.com.au/forums/topic/13524-mines-computer/#findComment-3814798
I have a Mines Tuned ECU in my R32 GTR. I only have a cat back exhaust, the rest of my car is standard (boost, turbos, etc....). In terms of reliability my car is perfectly reliable for the australia climate, RON of fuel (I use BP98). Cold starts are perfect, etc......
I aggree though with some of the guys here that if you want to start modding your car then you would need to look at a aftermarket ECU (pref aussie made one e.g. haltech) as there is local support and servicing). If you are going to leave it stock then enjoy the car as it is!!
my 2 cents......
https://www.sau.com.au/forums/topic/13524-mines-computer/#findComment-3814919
I also have one in the R32 GTR.
A bit rich, pops flames and all that jazz.
Car has run up to 1.1bar on stock turbo fine. Very cold night though.
Doesn't like certain fuels. The car runs a bit more sluggish if not on BP Ultimate.
I'm going to guess these things were tuned to run 100ron fuel. As there is a big sticker on the inside of my fuel flap with some japanese writing and "100ron!!!!" on it.
https://www.sau.com.au/forums/topic/13524-mines-computer/#findComment-3814943
Hi guys, My friend has just found out he has a Mines computer in his Z32 300zxtt.
What exactly do they do?
I understand that it is a remapped computer, but how much gain can we expect over standard?
probably about 20kw and a broken ring land!!!
They are no doubt alright on Jap fuel but they are no good on Aussie fuel. There is no such thing as being able to send the ECU back to Japan and have them modify the tune successfully!!! Every car is different and if they werent why would we need to create individual tunes for cars that have the same mods!!!
Get rid of it and buy a Power FC!!! your pistons and rings will be eternally grateful!!!!
https://www.sau.com.au/forums/topic/13524-mines-computer/#findComment-3814970
  • 3 months later...
Sorry to bring up an old thread but i have to ask..
I just recently went to install a safc and found that i have a mines ecu.
Now before i start solderin away, will the safc still work fine with a mines ecu?
I cant think of a reason it wouldn't but can you guys?
cheers,
-Trav
https://www.sau.com.au/forums/topic/13524-mines-computer/#findComment-4043224
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
