Well here is the story...I have a bog stock R33 S2 GTS-T Manual *4Door Sedan*
Anyway my mate has a R33 S1 Coupe running 14psi, front mount, full exhaust with a split dump & was going to run his so i thought i would go watch...anyway i never planned on racing as i finished work late but he called me & said there was not much people so i took my helmet & rego just in case...when i got there was was not many cars lining up to register so i thought what the heck.
Correct me if i am wrong but specs for a R33 Coupe say 14.7 for a stocker down the qtr so i was thinking since mine is an odd 40kg heavier being a sedan plus i had a full tank of ultimate which i filled night before plus i have a sub in my boot etc that i would run a low 15 or at best a really late 14
First pass was a bit nervous & stuffed up & it bogged down a bit after initial axle tramp but to my suprise i got a 14.6 with a 2.2 60ft & 95mph...i was like what tha f-ck? thats awesome
14.6.PDF
Next pass i took my air filter panel out of box to see if it went better. Again off start i bogged down again but only just & it squatted nicely off the line but missed my change from 3rd to 4th & hit limiter for a second or two & was amazed to pull a 14.3 with a 2.0 60ft & 96mph
14.3.PDF
3rd pass gave a bit too much off the line & spun & only did a 14.5 with a 2.3 60ft at 96pmh
14.5.PDF
Last pass totally stuffed it...bogged on take off & then went from 2nd into 5th so did a 16.1 hehe with a 2.3 60ft
16.1.PDF
Anyway i was totally surprised & I reckon on a colder night with newer tyres less fuel & sub etc out i could pull very close to a 14.1
What do you guys think & what have other stockies run before?
Edited by Noel
https://www.sau.com.au/forums/topic/135264-wsid-20th-sep-06/
oh & also without air filter panel felt alot more throttle response but also noticed it blew a bit of black smoke when i backed off ie running a bit rich...when i put panel back in still blew a tiny bit of smoke but barley as much?
why is that?
I think croat likes Drag Radials now. 7/10's off the PB in one meeting isn't bad at all.
Also, Noofa (Nathan) from Bezerkly Automotive had his first shot at racing last night in his R32 4-door. Straight into the 13's with a 13.9 @ 98mph is awesome for a first go. Huge congrats.
Adrian
What do you guys find is the best launch technique?
I found that lower revs (2000-2500rpm) dumping it with a bit of axle tramp/hop & bog was better than higher revs (3000+rpm) slipping the clutch or just dumping with a little bit of wheelspin controlled by throttle
Noel is your car TOTALLY stock?
Stock Exhaust
Stock Intercooler
Stock Rims
Stock Boost
etcetc?
What brand/size tyres were you running?
Impressive time either way!
:rofl:
Stock as they come...Only thing i have done is put a MP3 Player, Sub & Amp hehe
Tyres are Bridgestone Potenzas r16 205/55 i think about 50% tread
Oh...i did let tyres down to about 22psi (from 33psi) also
NSCC = Nissan Sports Car Club.
Let's just say that SAU and WSID aren't on the greatest of terms these days, so your best bet is to try and tag onto a private track hire day organised by another club - in addition to the club's mentioned by Ben, v8owners.com.au (i think) also organise them fairly regularly.
Private track days are excellent though - I got over 20 runs at the last SAU day and could have had plenty more.
im planing on going out in the next few weeks....I have a fairly stock r33 96 S2, just a pod and getting a split dump, 5"cat and 3" all the way. What kind of times should i be aiming for?
from my times in a dead stocker if you can get a 2.0-2.2 60ft you should crack a 13.9-14.1 i reckon with about 98-100mph with your mods...what do the rest of you think?
  • 3 weeks later...
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
