Modding on the car starts on monday and im still deciding whether to do
A) Full 3 inch turbo back exhaust with hi flow cat
OR
B) 3 inch cat back & FMIC
At this stage i dont plan on running anything over stock boost untill i get an EBC
Im starting to lean toward option B more because when i do decide to boost it i can do it somewhat safely with the fmic in place and get the dump and cat later on
Thoughts??
https://www.sau.com.au/forums/topic/135265-what-should-i-do/
You'll get similar results from both, but I would go Option 1.
Because to do the turbo back section later, you have to pull off the whole exhaust again anyway.
The Cat is more of a restriction than your stock FMIC.
BASS OUT
i agree with bass. and also on the fact that when you do wind the boost up it is better to have an exhaust that will let out the extra air that you are putting in.
also it is usually cheaper to buy a full exhaust system at once than to buy it in pieces (if you go the one brand).
