I've seen a couple of sets of the noltec ones (non-adjustable) and was also wondering about whether the extra collar helps with the durability - is anyone running them with big caster?
What we really need is upper arms designed with the extra caster in mind......*squints at gary*
A friend had the Nismo arms in the front of his R33 GTS25T. They werent adjusable but they were meant to be aligned for better traction at a lowered ride height. Having driven the car at Wakefield and EC it was a sensation compared to the handlign of my car.
So the Nismo arms for the GTR/GTST, do they solve/allow for this problem?
Otherwise, if i can get my hands on Visual Nastran then i can model it all in 3D and do the motion analysis on it to get some fixed length arms made up
The model would be great, but effectively the Whiteline kit makes the arm a fixed length - just shorter. I think what it needs it a slight twist in it so that the caster induced load in compression that occurs on the upper link bushes is reduced.
But without the model that is just supposition....
I doubt you would get a sheet load of people wanting them. They don't do anything other than repalce the standard ones & are non adjustable. The Whiteline gear is adjustable & for most uses appears to be fine.
I am looking for a set, however...
The R32 Nismo arms (I actually have a set) are EXACTLY the same as the standard arms, except they had “hardness up” rubber bushes. I haven’t ever seen a set of R33/34 Nismo arms, so I can’t speak for them.
:angry: cheers :)
LOL...really? You forget they are painted silver and have Nismo stickers on them! :P
Oh well...im worried about takign the car back out with eh clunkign on the front end. horrible noise and is pretty disconcerning. Sounds like im going to damage somehting big time :)
I just hope it sounds worse then it is
So that would price the silver paint at, what, about $130?
Got the Noltec bushes delivered. For once they cost less than listed price. :P $120 ish with postage. For the record they feel harder than the Whiteline bushes, despite all the palaver on the Noltec site.
Edited by djr81
  • 9 months later...
Sydneykid,
Slightly old thread but, Very interesting. How are you going with the upgraded camber kit for R32's? Any news regarding them yet?
My road going gtr needs either new upper arms or a better bush style camber kit installed compaired to the Whiteline kit currently available. All products using sealed bearings like Midori and Nolathane arms are designed for track use only and are too harsh for street driven cars and illegal.
Picture of new Nolathane arms attatched
Love to get my hands on these Gary
The issue with R32’s chewing out bushes in the front upper control arms is a known problem, hence why Nissan changed to the wide spaced inner pivot joints on R33’s and R34’s.
As a few of you know, I am currently testing a revised camber kit for the front of R32’s. The revision is to allow more camber adjustment by utilising an offset crush tube in both the inner and outer joints. The normal camber kit only has an offset crush tube on the outer joint.
As well as allowing more camber adjustment, less negative camber for excessively lowered road cars and more for circuit cars, it will add more compliance into the upper arm inner pivot joints. This should noticeably decrease the propensity for the (current) low compliance inner bush to be chewed out by the distortion caused by the R32 geometry. Which (as a couple of you have found out) is exacerbated by increased camber and (mostly) caster.
The off the shelf KCA336 kit contains both alloy and poly bushes for use in the inner pivot point, refer picture following;
What I am testing uses full polyurethane bushes (no alloy) in the inner pivot point,.with an offset crush tube for adjustment This will allow capacity for more of the inbuilt distortion (on suspension movement) to be absorbed by the thicker shanking on the bush. Following is a picture of a Nismo upper control arm with the adjustable bushes installed in the inner and outer joints.
Post picture here
I have only just started road testing, so it is early days yet. I will also be carrying out some circuit testing in the R32GTST. If it stands up to that punishment then I will be offering the upgrade for those that want/need it. More updates will be posted as they occur.
:thumbsup: cheers :domokun:
PS; it is worth mentioning at this time that the Group Buy price on the KCA336 (for R32’s) and KCA348 (for R33’s, R34’s and Stageas) has been reduced from $272 to $183. This maintains the 15% discount on the Whiteline retail price (20% if the order is over $1K).
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
