nothing...chances are they are just as hard and stiff as the other two models.
Look at dampening and height adjustability between the models.
What sort of power does your 2530 put out?
Edited by r33_racer
https://www.sau.com.au/forums/topic/135289-coilovers/#findComment-2515504
umm its in getting tuned atm but b4 that it had 350 ish at wheels on 16 psi
https://www.sau.com.au/forums/topic/135289-coilovers/#findComment-2515516
i just sold the old coilovers off my car,it had tein type hr on the rear and ha on the front,sold for $350
Edited by mjones
https://www.sau.com.au/forums/topic/135289-coilovers/#findComment-2515790
  ookami said:
I didn't think they made either of those models anymore do they? Just make sure you check the spring rates, or you'll end up with a ruff handling car.
ok thanks are the hr damper adjustable and what spring rate is good
https://www.sau.com.au/forums/topic/135289-coilovers/#findComment-2516860
well ill put down my opinion of jap spec tein HA's...pure crap. I even swapped spring rates down to something more sensible and it was still bloudy shocking. Poor design, poor setup with spring rates. Mind you this is for a track car, not road car. But ive had a set in my old sil80. Still the same problems though.
Heres a little bit of real world difference. Race car with teins meant no weight transfer, so off the line wheelspin was enormous. Race car with no teins, replaced with SK's setup and actual weight transfer occuring saw the wheels get traction and then spit the tailshaft out. Moral is unless your wanting to drift or you just like a real stiff ride with lots of bumps and jolts then stay away from teins(cant talk about aus spec, dont know them yet). However if you want a good ride with good handling and a sporty feel try the bilstein group buy.
https://www.sau.com.au/forums/topic/135289-coilovers/#findComment-2517264
I have the super streets on the 32. Absolutely unreal handling. They are also compatible with the electronic controller (EDC). I would recommend them to anyone, even those with track cars. RGM Maintenance's R32 GTR targa tasmania track car gained (I think) 5 places just from swapping from the Jap spec to the Aus spec Teins.
https://www.sau.com.au/forums/topic/135289-coilovers/#findComment-2517669
I'll agree with this. I had 2 setups before the bilsteins went in. And they are by far the best (2nd set up was 100% custom for the car, the bilsteins are still 10x better) Better quality, better ride, better handeling. And cost lest (for me at least) than the fulcrum tiens would have. I also tried different suspension settings with all set ups to make sure it wasnt that.
https://www.sau.com.au/forums/topic/135289-coilovers/#findComment-2517957
im only getting the front set of hr not the rear my car at the moment has tein suspension in it but there not adjustable and there stiff as shit ive had them checked and the guy said there not coilovers but deffinatly tein so i dunno the reason i want the hr's for the front is because my front left corner has dropped a couple of centimeters probably due to stuffed spring and some adjustable suspension could cure this
https://www.sau.com.au/forums/topic/135289-coilovers/#findComment-2522534
Dude, not trying to tell you what to do... But wouldnt finding out what the problem actualy is be a good idea before spending money if you dont need to.
But hey, if you want them anyway then by all means just change them. But if its not what the problem is then your throwing money away.
https://www.sau.com.au/forums/topic/135289-coilovers/#findComment-2523326
Best all around handling skyline I've been in had Ohlins - GTR though. Then again I don't like the weight transfer of the softer spring rates SK is selling. If your using it on the street don't go crazy on the spring rates. Even the 8kg font\6Kg rear setup in my old R33 was too stiff for daily street driving espically on the highway!!
https://www.sau.com.au/forums/topic/135289-coilovers/#findComment-2523835
  not2.5 r33 said:
yea i want them anyway and it is a crook spring so im not throwing money away so its all good
Well if its the sring, just get another spring :)
Either way the bilstiens are the better option.
https://www.sau.com.au/forums/topic/135289-coilovers/#findComment-2527460
  dangerous_daveo said:
Well if its the sring, just get another spring :pirate:
yea i understand and agree with you although im getting these front coilovers for like 300 delivered and to me that is a quick fix for my lousy spring the suspension in my car atm is old and the sooner i get rid of it the better i dont really have the money atm the fork out for a full set of bilsteins which im guessing would cost around 1500 ???????
https://www.sau.com.au/forums/topic/135289-coilovers/#findComment-2530687
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 馃ぃ And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 馃お
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
