Help with theme for PAS Autosalon
Well, Nissan says So factory expects 0.11Mpa or or 110kpa or 1.1bar or 16psi (which feels low to me, but there you go)
Ok thanks guys that is what i thought and learned from all the comments/videos too. If i want to BoV i need/want to have standalone ECU 🙂 And the bypass valve tge car has is good for stock(little bit more) power.
By myrbgivesmeheadaches · Posted
Wait so is it heaps low or double what it should be..? -
That's heaps low tbh Is your oil pump factory? -
You typically expect about 100 kPa at idle - 1000 rpm. You're in the region of double that.
