Hi Guys,
As many of you know we are planning an SAU entry into this years PAS Wester Salon (if you don't, read the Events section).
We have decided to go for a race theme and although we have a number of ideas we would like your input into what things you would like to see us do.
We all have our likes and dislike so please tell us what yours are so we can try and make it an impressive display.
So please help us by letting us know what ideas you have, along the lines of a race theme.
See'ya:burnout:
Paul
https://www.sau.com.au/forums/topic/13530-help-with-theme-for-pas-autosalon/
  • Replies 70
How about a TV/monitor next to each of the display cars showing someone like gtrken (or other talented driver) giving that particular car a little work out at a trackday or mc day or summit?
I would like to see what a car can do, not often you can tell what a car can go like by how it sits in a paddock.
- a rear projector will sort out lighting issues
- get a large banner made up obviously
- put on your shirts and make sure the entered cars have the sau stickers
- get one guy whose skyline is more music orientated and crank the tunes
- have a track day or something befor ethe auto salon and enter the cars, and like jon said gets vids from them, and pics (otherwise you might have ricer theme with pauls car :D)
just an idea similar to shuto-boy's.
-have it set up like a pit lane etc with fuel drums (empty) and pump and stuff like that if you can get it.
-would look cool if you could get an rb engine on its own and have ken or someone work on it all the time like a mechanical display thingo.
bit far out there but there you go....
i am with epoch and aidwin, i was thinkin of like pits, or a garage with parts and tools around the place and we should make it look like nick's car is up on a hoist and shit , and if we feel really cool have sau overalls so we look like mechanics hehehehe
adrian :)
I have seen a display at one car show that use the corner of a race track (made to look like one) with the cars mount with two wheels on the ripple strip, looked great and would be easy to do, maybe could have a pits setup as well. I will keep thinking.
Have lots of tyres stacked up everywhere you can make it really interesting by having a smoke machine or lights inside a stack of tyres so you get smoke coming out the top
Also seeing as this is pretty far away maybe by then you could have that SAU jacket idea done up so everyone has a cool racing jacket on! thatd really show every1 how its done!:)
Originally posted by GTS-t VSPEC
Jon,
Thanks for that, we were planing either a TV or projector with footage from gtrken, MC Motorsport day, cruises etc. We're not sure if the lighting will allow for a projector on not.
See'ya:burnout:
Heyas
i really don't think a projector is a good idea, due to light issues... if not your own then everyone elses that has lights all over their display it really will be lit up a lot.... at cabin there was one projector display for lextc but he had it in a fully sheltered cloth tent so people could see the projector.
maybe if you had a few black sheets to surround the projector and the screen to block out light....?
monitors or always nice and easy.... James Mandy owner of PULSSSAR has always used a nice monitor with a power point presentation... goes down VERY well with the judges it outlays what he has done inthe builds and how he has done it...
i think most importantly is the SAU banner and the people in their SAU t-shirts and stickers and jackets etc...fancy displays may not be remembered but SAU must be permanently imprinted in the minds of all showgoers :)
also Adrian giving out Nandos chicken with Aidwin dressed as Party Boy Japan
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
