Theres lots of posts about spark plugs on here but ive got a question.. :D
R33 gtst usual mods standard turbo..
Re-moved "iridium nismo 8" spark plugs from car (god knows what these are? 0.8 gap?)
Put in NGK Iridium BKR5EIX-11, gapped to 0.8 (i know you're not supposed to gap iridiums).
I wanted to put in BKR6EIX, but id allready bought the BKR5EIX.
Running with the BKR5EIX 's the engine wasnt even coming onto boost it was just pinging and spluttering everywhere.. with low down torque not really there either..
I put the Old iridium nismo 8 plugs back in and all is now good and back to normal..
So im guessing the Iridium BKR5EIX (5 heat rating) is too hotter a plug?
I know i should have the 6 heat range, BKR6EIX, for the kind of mods i have, but would the 5 really do this kind of thing to the performance of my 33?
Any feedback would be great.
Looks like ive just wasted $100 on the damn wrong heat range sprakies.. :( , Dumbass.
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/
Theres lots of posts about spark plugs on here but ive got a question.. :nuke:
Looks like ive just wasted $100 on the damn wrong heat range sprakies.. :) , Dumbass.
Yah think you have got yourself some hot plugs, put it ip in ebay and sell at half the cost. At least you can recover something back.
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2517133
you can't go past the plugs with the code BCPR6ES. they are only copper and are about $3 each (better than about $20 each for iridiums). i've had mine in for about 10,000kms at between 12 and 14psi and they haven't missed a beat. it had iridiums in there and they were dead after 20,000ks. i'm going to change them again at the next oil change (at $24 a set, why not)
but a guy i know put platinum plugs in (heat range 5) and it pings like a bitch, and pops and farts. he took me for a spin in it last night, but he wouldn't listen when i told him his plugs where wrong (1 of those know-it-all types).
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2522759
Sometime cheap is not necessary bad and expensive is not necessary good. The key is to choose the correct form, fit and function that cater to your engine. The BCP6ES are without the V groove, choose the BKR6E-11 (gap down when necessary) which cost around there too.
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2522802
It all depends on the mods you have.
a mildly modded car shouldn't have major issues running a 5 as they are the stock replacement plug.
A 6 heat range plug is a good move with more boost up to about 1.1bar/16psi. bcpr6es/bkr6es is .8 copper out of the box, bcpr6e or bk.. is the v groove option.
A 7 over that up to low 20psi
I'd start with a 6 bcpr6es as they are cheap enough. If no good then make a few enquiries about the nismo plugs and try a copper 7.
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2522889
cheers fellas..
Yeh ill try the bcpr6es hopefully the 6 heat range is better. didnt realise a 5 heat range would be so S!@T
I might even keep the old nismo 8 iridiums in there and just clean them gently..
Ive got the old typical coilpack hairline cracks too, might fix them up as ill probably need too one day anyway..
thanks for the confirmation about the plugs.
Lata.
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2539658
hey i am more or less going through the same thing i have been using 7es in my 33 and have had no real problems went to enquire about iridiums and could get them for about $18.oo each and the same for platiniums but could not get them in 7,s ended back with old faithful bcp7es for grand total of $21.00 ,cheers
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2540931
Don't know if this has been said but you can't compare all plugs by their number e.g. 5 or 6 as some plug manufacturers hotter and colder plugs ranges move in opposite directions.
yeh cheers, i know, i was just talking about ngk's.
ill be going the $21 option too.. ;)
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2570605
mine was missing on boost...heat shrinked my coils and gapped my plugs at 0.8 that fixed it...then turned the boost up to around 12psi and it started missing again so i went for the bcpr7es gapped at 0.8 and everytihing is now sweet! id definatly recomend going for the 7...+ it costs like 24 bux!
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2570952
i'm using the bcpr6es and i'm running 14psi with stock coils. they pop and fart on the very odd occasion, but they are about 7000km old. i'm going to go to the 7 heat range on the new plugs, just to get the heat down.
Remember to check your colder plug for fouling...
NGK FAQ
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2571819
You can't go wrong with the BCPR6ES plugs. I had a set of splitfire plugs in mine which cost around the $20 a plug mark. They lasted all of 3 weeks before they started missing. Then the car sat for 2 weeks in the spray shop and i went to pick it up and it wouldn't start!
A trip down to Autobarn and 6 x BCPR6ES later and they haven't missed a beat. This was in October last year as well so they're probably due for a change! :P
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2574762
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
