Theres lots of posts about spark plugs on here but ive got a question.. :D
R33 gtst usual mods standard turbo..
Re-moved "iridium nismo 8" spark plugs from car (god knows what these are? 0.8 gap?)
Put in NGK Iridium BKR5EIX-11, gapped to 0.8 (i know you're not supposed to gap iridiums).
I wanted to put in BKR6EIX, but id allready bought the BKR5EIX.
Running with the BKR5EIX 's the engine wasnt even coming onto boost it was just pinging and spluttering everywhere.. with low down torque not really there either..
I put the Old iridium nismo 8 plugs back in and all is now good and back to normal..
So im guessing the Iridium BKR5EIX (5 heat rating) is too hotter a plug?
I know i should have the 6 heat range, BKR6EIX, for the kind of mods i have, but would the 5 really do this kind of thing to the performance of my 33?
Any feedback would be great.
Looks like ive just wasted $100 on the damn wrong heat range sprakies.. :( , Dumbass.
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/
Theres lots of posts about spark plugs on here but ive got a question.. :nuke:
Looks like ive just wasted $100 on the damn wrong heat range sprakies.. :) , Dumbass.
Yah think you have got yourself some hot plugs, put it ip in ebay and sell at half the cost. At least you can recover something back.
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2517133
you can't go past the plugs with the code BCPR6ES. they are only copper and are about $3 each (better than about $20 each for iridiums). i've had mine in for about 10,000kms at between 12 and 14psi and they haven't missed a beat. it had iridiums in there and they were dead after 20,000ks. i'm going to change them again at the next oil change (at $24 a set, why not)
but a guy i know put platinum plugs in (heat range 5) and it pings like a bitch, and pops and farts. he took me for a spin in it last night, but he wouldn't listen when i told him his plugs where wrong (1 of those know-it-all types).
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2522759
Sometime cheap is not necessary bad and expensive is not necessary good. The key is to choose the correct form, fit and function that cater to your engine. The BCP6ES are without the V groove, choose the BKR6E-11 (gap down when necessary) which cost around there too.
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2522802
It all depends on the mods you have.
a mildly modded car shouldn't have major issues running a 5 as they are the stock replacement plug.
A 6 heat range plug is a good move with more boost up to about 1.1bar/16psi. bcpr6es/bkr6es is .8 copper out of the box, bcpr6e or bk.. is the v groove option.
A 7 over that up to low 20psi
I'd start with a 6 bcpr6es as they are cheap enough. If no good then make a few enquiries about the nismo plugs and try a copper 7.
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2522889
cheers fellas..
Yeh ill try the bcpr6es hopefully the 6 heat range is better. didnt realise a 5 heat range would be so S!@T
I might even keep the old nismo 8 iridiums in there and just clean them gently..
Ive got the old typical coilpack hairline cracks too, might fix them up as ill probably need too one day anyway..
thanks for the confirmation about the plugs.
Lata.
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2539658
hey i am more or less going through the same thing i have been using 7es in my 33 and have had no real problems went to enquire about iridiums and could get them for about $18.oo each and the same for platiniums but could not get them in 7,s ended back with old faithful bcp7es for grand total of $21.00 ,cheers
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2540931
Don't know if this has been said but you can't compare all plugs by their number e.g. 5 or 6 as some plug manufacturers hotter and colder plugs ranges move in opposite directions.
yeh cheers, i know, i was just talking about ngk's.
ill be going the $21 option too.. ;)
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2570605
mine was missing on boost...heat shrinked my coils and gapped my plugs at 0.8 that fixed it...then turned the boost up to around 12psi and it started missing again so i went for the bcpr7es gapped at 0.8 and everytihing is now sweet! id definatly recomend going for the 7...+ it costs like 24 bux!
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2570952
i'm using the bcpr6es and i'm running 14psi with stock coils. they pop and fart on the very odd occasion, but they are about 7000km old. i'm going to go to the 7 heat range on the new plugs, just to get the heat down.
Remember to check your colder plug for fouling...
NGK FAQ
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2571819
You can't go wrong with the BCPR6ES plugs. I had a set of splitfire plugs in mine which cost around the $20 a plug mark. They lasted all of 3 weeks before they started missing. Then the car sat for 2 weeks in the spray shop and i went to pick it up and it wouldn't start!
A trip down to Autobarn and 6 x BCPR6ES later and they haven't missed a beat. This was in October last year as well so they're probably due for a change! :P
https://www.sau.com.au/forums/topic/135310-hot-spark-plugs/#findComment-2574762
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
