Time to get my water pump changed on my r32 gtr. I'm thinking about paying extra and getting the N1 waterpump installed as a good upgrade. However i've been told by a respectable tuner that the N1's would not work very well under normal driving conditions (in traffic, in the middle of an aussie summer with the airconditioning cranked up) and might cause problems. Apparently i've heard that the N1 water pumps only works well under high Rev's for long durations. Can anyone clarify this for me?
https://www.sau.com.au/forums/topic/135325-r32-gtr-n1-water-pump-vs-standard/
Heres the 2 side by side:
Your tuner is right in saying N1 pumps don't flow as much as standard in normal driving conditions. If the revs are higher then the quantity of water pumping through the system is not bottlenecked as the standard one would be moreso.
mines upgraded to n1 and never had issues with overheating when cruisin around under 4000rpm for over 1200km or so. must admit it hasnt been 40 degree weather though so that will be a test. didnt move 1 degree on the dyno for a 4-5 hour tune session with various loads on the engine so it seems to be fine.
just my 2c worth :(
Mines N1, never seen the water temp go up over normal, even when thrashing it in really hot weather, also in traffic when i use it as a daily, even with ac on, there's no issues
Some will argue with that, but ive never had a problem with the water temp :(
Hope that helps
Thought i'd add this in for future reference incase anyone searches the forums regarding this topic. I've confirmed these few details with a few mechanics who specialize in GTR's:
The real difference between the N1 pumps and standard pumps is the N1 pumps stop cavitation at higher RPM's. One tuner mentioned he had standard GTR water pump on his 680HP GTR without any adverse effects. People with high HP track cars doing endurance runs (holding revs over 5000+ rpms for a good period of time) will see real benefits from a N1 pump. The standard gtr water pump is around AU$189, the N1 is about AU$400. Physically the N1 has a bigger 6 fin arrangement (see pic above) and an extra hole (apparently) the standard GTR pump has a smaller 8 fin arrangement. From my own experience, street driving with the standard pump vs the N1, I've seen no real increase in cooling performance with the N1, its still the almost same as standard. Bear in mind I dont push my car hard at all. I suppose I'll take solice in the fact that if I belt it hard, my water pump wont go :angry:
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
