brizzi Posted September 21, 2006 Share Posted September 21, 2006 Just how strong are these gearboxes? Obviosly not too strong!! Went all out got rid of the rb20det 5 speed and put a rb25det 5 speed in tailshaft mods,speedo drive etc etc.. Driven for three months no noises what so ever.... Then second gear into third the smorn hit boost then bang! No other gears except second and fourth... And rattle all the way back home to get the stagea to drive to work... Does any one know the damage, by all them symptoms? Cheers if anyone can help? Im sick of changing gearboxes this is number 5 on the list of skyline gearboxes i have murdered! Anyone help? cheeers Link to comment https://www.sau.com.au/forums/topic/135381-how-strong-are-rb25det-manual-gearboxes/ Share on other sites More sharing options...
R31Nismoid Posted September 21, 2006 Share Posted September 21, 2006 The gearboxes are tough as mate. Do you know the condition and the life of the box before you purchased it? Thats most likely where the damage has come from. Previous owner If you've killed 5 boxes, then i think it could well be your driving Link to comment https://www.sau.com.au/forums/topic/135381-how-strong-are-rb25det-manual-gearboxes/#findComment-2518325 Share on other sites More sharing options...
brizzi Posted September 21, 2006 Author Share Posted September 21, 2006 I want side step rev limiter strength! Link to comment https://www.sau.com.au/forums/topic/135381-how-strong-are-rb25det-manual-gearboxes/#findComment-2518506 Share on other sites More sharing options...
r33goodz Posted September 21, 2006 Share Posted September 21, 2006 as r31nismoid said, these gearboxes are about as tough as any going around. that said, any gearbox will eventually break from constant 6k launches...may want to revise your driving style. also, when buying a second hand box, and go and get it rebuilt properly or at least checked out. a box that has been broken then rebuilt is better than a second hand box as you won't know the condition its in. not sure how you lost 1st and 5th gears, but it sounds like you have stirpped 3rd gear. i'm also assuming you still have reverse? Link to comment https://www.sau.com.au/forums/topic/135381-how-strong-are-rb25det-manual-gearboxes/#findComment-2518537 Share on other sites More sharing options...
R31Nismoid Posted September 22, 2006 Share Posted September 22, 2006 I want side step rev limiter strength! They will take that no problem here and there The enemy of a gearbox is traction... ie drag strip + slicks/sticky as rubber... and big power. Also putting that kind of strain cconstantly on a box isnt going to help it either. Here and there shouldnt be much of an issue I doubt there is anything that will ever last constant abuse You shouldnt need to be doing that anyway, even if you are drifting... which if you need to do so, you need more skills and a better setup car Link to comment https://www.sau.com.au/forums/topic/135381-how-strong-are-rb25det-manual-gearboxes/#findComment-2521517 Share on other sites More sharing options...
2BNVS Posted September 22, 2006 Share Posted September 22, 2006 yep these boxes are definatley strong...runnin 500rwhp in mine and havent touched it internally ben... Link to comment https://www.sau.com.au/forums/topic/135381-how-strong-are-rb25det-manual-gearboxes/#findComment-2521798 Share on other sites More sharing options...
