Just how strong are these gearboxes? Obviosly not too strong!! Went all out got rid of the rb20det 5 speed and put a rb25det 5 speed in tailshaft mods,speedo drive etc etc.. Driven for three months no noises what so ever.... Then second gear into third the smorn hit boost then bang! No other gears except second and fourth... And rattle all the way back home to get the stagea to drive to work... Does any one know the damage, by all them symptoms? :) Cheers if anyone can help? Im sick of changing gearboxes this is number 5 on the list of skyline gearboxes i have murdered! Anyone help? cheeers :)
The gearboxes are tough as mate.
Do you know the condition and the life of the box before you purchased it?
Thats most likely where the damage has come from. Previous owner :rofl:
If you've killed 5 boxes, then i think it could well be your driving
as r31nismoid said, these gearboxes are about as tough as any going around. that said, any gearbox will eventually break from constant 6k launches...may want to revise your driving style. also, when buying a second hand box, and go and get it rebuilt properly or at least checked out. a box that has been broken then rebuilt is better than a second hand box as you won't know the condition its in. not sure how you lost 1st and 5th gears, but it sounds like you have stirpped 3rd gear. i'm also assuming you still have reverse? :rofl:
I want side step rev limiter strength! :(
They will take that no problem here and there
The enemy of a gearbox is traction... ie drag strip + slicks/sticky as rubber... and big power.
Also putting that kind of strain cconstantly on a box isnt going to help it either. Here and there shouldnt be much of an issue
I doubt there is anything that will ever last constant abuse
You shouldnt need to be doing that anyway, even if you are drifting... which if you need to do so, you need more skills and a better setup car
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
