  • Replies 120
Originally posted by darK
u seem to know a lot about this stu...
hehe yep i know alot because sniffy called me from the front seat of the car while they were waiting to cut him out(he told me to bring the camera down to capture the moment), and i went down there, thats how i got the pics and then i followed them to the hospital and was speaking to sniffy and vickii there
so yeah i am a bit of a know it all.
stu knows everything............:shake:
I cant believe this shit, maybe it was my fault coz they were comin to my place for dinner :)
I just hope that they are ok, the car doesnt look in good shape.They gave me a message and told me they wern't coming coz they were in an accident, although Vicki stated in the msg that she was ok and it wasn't serious. I would have assumed it was a lil one and told its ok, although after seeing the car it looks pretty bad.
:D
hey dont worry makaveli they were going into the city to get something for sniffy, then they were gonna goto your place, so they werent on their way there. hehe vickii asked me twice before they left if i wanted to come....lucky im a lazy prick and told her i couldnt be ****ed and didnt go with
i dunno sniffy called me pretty casually as though nothing happened, he was like yeah dude, we hit a tree im sitting in the front seat waiting to get cut out...i was like wtf.....so i went down there and then i saw the car ......it was pretty freaky
anywayys im gonna go back down there now see whats going on sniffy will need a ride home...so yeah bbl
Originally posted by Horus
okay I just spoke to the Alfred, Vickki is okay atm, but they ned to do a few more test before they release her
Sniffy is ok as well, according the doc, he got a few stitches but should be fine in the long run
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
