Hi guys I am gonna be getting some new rims for my car soon and I dunno about the offsets and stuff like that for the car, I've done a few searches but have no clue lol. Anyway I was after 17 inch Volk f-zero challenge rims. Also what would happen to the spare tire in the car? do I need to get 5 17 rims to put 1 spare in the boot? Thanks! :mellow:
https://www.sau.com.au/forums/topic/135446-getting-new-rims-for-r33-s1/
Regarding the spare... No, you don't need to get 5 17" rims. But you can if you want.
If you ever need to use the spare though, only use it temporarily and NEVER, EVER but it on the rear.
If one of your rear tyre's blows, replace it with one of the wheels from the front, and put the space saver on the front.
This won't kill your LSD as fast as putting the space saver on the rear will.
You might have a working LSD, but you will also have reduced steering response and braking grip!
I'm pretty sure that you only ever use the space saver on the rear. If you get the correct size tyres fitted to the new rims, then you should have the correct rolling diameter to not put any stress on the diff.
Agreed...............
Fit the space saver on the rear. I'd rather have braking and handling, any day.
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
