Hi guys,
I was just curious to how can you hook up subs onto a computer?
Is it possible? I imagine you would still need an amp, I wonder if you can use the one in the car?
The reason is I have old Fusion amp and 2 x 12" subs here lying around at the moment.
Just curious if its possible... or maybe atleast hook it up to dvd player or something.
Any ideas?
Cheers
https://www.sau.com.au/forums/topic/135468-can-you-use-subs-on-computer/
Thanks, you wouldn't happen to have a link to the amp at jaycar would you? Sorry don't really understand how these things work... thats why I got a professional to install mine in my car.
Can't I use the fusion amp?
Mind you I don't really want to burn or blow anything in the end.
Also I just want to avoid spending more money.
Just thought if it was possible to use them
Edited by aquariuz6
Best to use a dedicated 240v home amplifier, here is a link.
http://www.jaycar.com.au/productView.asp?I...=&SUBCATID=
Please be aware that that your subwoofer is 4ohm, so you could be generating quite a bit of heat from this amp (check that it's 4ohm stable).
If you wanted to use your fusion amplifier, then you'll need a 12volt convertor.
You're better off using a set of purpose built home computer speakers like Logitechs. I have a set of Yamaha 350wrms computer speakers, they cost around $300 at the time of purchase and they pump nearly as hard as my single 12 in the car at the moment.
You would need a pretty substantial power supply (read - expensive) to power your fusion amp, your best bet if you want to use them with your puter' is buying one of the jaycar amps like Howie found and getting a 3.5 mm splitter and a 3.5 to rca lead - they can help you out with these at Jaycar (cant tell I used to work at Jaycar eh?)
a 40 amp power supply should do the trick and they are available from car audio distributors for anywhere between 450 and 2000 dollars.
One thing to think about to is the level the amp will see. Your computer from a set of rca style outputs will only have a weak signal output, probably less than 1 volt.
A car audio amp is designed to see between 2 and 8 volts generally.
so you will need to run a line driver, car eq etc to boost up the signal before it goes into the amp, otherwise no volume.
Or...
Go to Jaycar, buy the piece of crap amp, wire your 2 subs at 8 ohm so the amp does not shut down and you have bass.
This is the easist most cost effective way to do it.
if you are going to use it at home then buy a sub-amp for home (240V)
this will eliminate the 12-13.8VDC power supply.
only buy sub-amp as it would have a built in low pass filter.
do not buy a home theatre or a standard stereo amp as it will be a waste of time.
the line level coming from your PC will be in the form of 3.5mm stereo socket (earphone type) is perfectly fine at 1 Vp-p (standard). just buy a converter lead to go to 2 RCAs and you will be fine.
http://www.skylinesaustralia.com/forums/in...=128025&hl=
hope this helps :P
need any info let me know!!
This is what im running at home..
Sub-- Boston Comp sub in custom made box with jaycar module amp running 350 rms.
Check above link!! :huh:
Edited by siddr20
to ad a sub to a computer u can buy a sound card then buy a seround sound package ment for for a pc
then you could probley buy a sub from a hifi place or connect a sub up with a lil wire mod
:laugh:
hope that helped
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
