Hey guys Ive posted this up in another part but cant seem to get any response, to anyones knowledge is there anywhere else in the engine bay that i can tap into the line to use?
http://www.skylinesaustralia.com/forums/in...p;#entry2520503
Thanks, Tim
https://www.sau.com.au/forums/topic/135503-need-a-little-help/
underneath your intake piping that goes across your engine there should be two vaccum lines. theres a good chance one doesnt go anywhere and is blocked off. you can use that to run to your bc. basically u need a vacuum line that goes from behind your butterfly straight to your bc then straight to your wastegate.
