Just had the auto gbox done in my missus R34 GTT, was slipping goin into 2nd gear. the guys had a look pet new oil in, adjusted the bands etc and it still slips they believe it has a glazed drum or band.
My question is? Are all R34 auto gbox's the same? The place i took it said he dusnt even list the type of gbox.
Any idea's on the cost of rebuilding one?
Any suggestions?
thanks
https://www.sau.com.au/forums/topic/135505-r34-gtt-auto-box-problems/
This happened to me.
It is on the way out and will never recover on it's own or with fluid changes or adjustments.
I can find you a second hand one if you want - pm me - and this is the cheapest option.
I had mine rebuilt by MV Automatics in Adelaide. It is well worth freighting to Mike because he is the only person in Australia who actually knows these boxes despite what other people might tell you about their skills.
Cost about $3500 plus freight from memory with upgraded stall converter, valvebody, servos, kevlar bands, etc etc to handle at least 300rwkw.
yeah i thaught it would be finished.
I'll probably go the second hand one as i have one for sale atm, the car is under warranty so i will make them pay (they wont cover a rebuild as they only go up to $2000)
Im not fussed about making it handle more power as its only her daily, its only gonna have basic mods: exhaust, FMIC, SAFC etc
thanks for the help
    • Ah. OK. I take it back. I hadn't looked closely at the R33/4 arms and presumed that GKTech did as GKTech do everywhere else, which is to use sphericals there. The poly bushings are made to be 100% interchangeable, should use the standard bolt just fine. Every other bush in every other place in pretty much every other car, does.
    • @silviaz Ok cool, so much easier with a video. I can see why this video would be confusing for new players.   It is obvious that this entire bonnet is going to be resprayed, have a look in the background around 2:05, you can see a bunch of bare metal on the left side of the bonnet.  It's not an issue for the primer being laid down on the non-prepped clear on the bonnet. It will be sanded off at a later stage.  This might not be obvious to new players, but working on bare metal and factory paint in this instance, the factory paint is like a mountain and the bare metal is a huge valley. The bonnet needs to be levelled flat before it receives it's final stage of colour and clear coat. During this levelling process, the primer that is landing on the clear that you are worried about will be removed.  Also, this guy is out of control. Zero PPE while spraying, maybe he is a good example overall about what not to do lol.
    • Ok I FINALLY found a video lol. This took way longer than it should have as I could have sworn I saw multiple videos like this. I kept finding the completely opposite (the correct way of doing this). I wouldn't be surprised if I f**ked this up somehow.  I just realised where I've been getting confused and even with other things I work on. I haven't been doing things the regular way instead I'm going a roundabout way of doing things, like putting epoxy primer first then filler for example instead of putting just filler then primer on top of that, then wondering what happens if I get that primer on the clear coat that I haven't sanded yet. This was a bit of an epiphany 馃槀  But anyways, here this video. Time stamp, 2:56, some of the primer lands on the paint unscuffed above. You can see from the reflection it looks shiny.
    • It does, this part circled in red. I assume the OEM bolt might not work well with the poly bushing because the dimensions may be different?
    • The J arm doesn't have bushes either. Assuming that by "J arm" you mean the part of the upright that runs down from the upper arm's outer bushes to the top of the hub. That has a kingpin style bearing in it. If you meant the lower control arm, it has 1 bush, at its inner end. If you have PU in there, that is superior to Nismo rubber. If you meant the caster/tension rod - it has 1x bush at the front end, and again PU is superior to Nismo rubber. But as I said above, I would definitely get the GKTech arms for that, as sphericals slay all other options there.
