hey guys, i am thinking of lowering my car, i done abit of research and found out that aftermarket springs will make my ride very stiff and bouncy, or the other way is to get my stock springs resetted to what height i want, and it will make my ride feel liek stock? is this true? will it be bouncy liek aftermarket springs? can any1 with experience tell me how it rides?
thanks
Well all I can tell you is that my car came with reset springs and they are next to completely stuffed. The front spring rate is a lot softer softer than stock and although it remains captive at full droop, it actually compresses so much the car sat on the bump stops. The rear is stiff as, much stiffer than they should be. It basically is rock solid. The springs were Eibachs which got reset by the old owner. So yeah.. I don't recommend it. Whiteline springs in my experience are not much harder than stock and are definitely worth looking at.
Edited by Busky2k
If you get an actual suspension manufacturer to reset the springs, I'd say that you'll get what you want.
But if you're letting some random do it on the cheap, then I very much doubt it. How many of these "spring resetters" have the tools to measure the spring rate of their finished product? Anyone with a ruler can measure the height, but if they can't measure the rate they can't even guarantee that your springs will have the same rate as each other anymore, let alone the rate of OEM.
You can go get custom springs made up for under $500 by a proper spring manufacturer. I'm pretty sure King, and Whiteline, will be able to sort you out. It may cost more but at least you know the guy making it actually knows what he's doing.
ahh ok no worries, thanks for the help guys, mite just leave it or get some tien flex coilovers, heard they are very good for street
I find them a bit stiff (but then I don't own a Skyline). If you're complaining about a bouncy ride, you might want to consider something softer. Super Streets maybe. Or if you don't need the adjustability, a lot of guys in different cars find that Eibach springs and Koni dampers tend to be great for the street.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
