Guest EVL-R33
ey ive got a problem with my gears crunching as all of us do.. i changed my oil and it still crunches...
i see the thread for Redline Lightweight shockproof oil and it soudns the go
sorry if this has been answered But WHERE can i get it from in Melboune???
and how much does it cost? coz u need 2.6 ltrs for a r33
thank u
https://www.sau.com.au/forums/topic/13561-redline-oil/
we put another box in my 33 last weekend. my mate's 33 owners manual said 2.8l so we just added that amount which we filled from inside the car with the shifter out.
To me there is something just not right about the feel of it all.
Reading thru old posts it seems if you fill it the conventional way (till it starts coming out of the side bung) you will use approx 3.6l
the 2.8l figure might be a leftover from the r32 turbo manual?
https://www.sau.com.au/forums/topic/13561-redline-oil/#findComment-268203
  • 3 weeks later...
