Stock gts intercooler/performance
Guest skybound
im kinda new in terms of turbo cars and have just purchased an r33.... sorry if these questions are lame! but is a stock r33 intercooler any good or should i get it changed - also what should i first start to add or change on my car to improve its performance.. basic stuff to start :D
https://www.sau.com.au/forums/topic/13562-stock-gts-intercoolerperformance/
Hi Skybound,
The stock intercooler is not much good at above factory boost, so if your after performance then a front mount intercooler(FMIC) is a must.
The first thing is to replace the factory exhaust system, a full exhaust from the turbo back is best. Then things like increase the boost, pod filter etc.
See'ya:burnout:
I agree with shuto-boy, you don't need huge-ass intercoolers, since you'll experienCe l ag if it's too big
and as paul said, don't bother yoursElf with the branded intercoolers as thats just an extra 1ooo bux on the price
juSt go a suitably sized (for thE amount of power) custom core, frOm a tRuck or whatever, and get that put in
welcoMe you too btw as well :)
p.s - cAn you please buy mE a nEw keyboard while yOu're out???? thIs o ne is ROOTED!!
Did someone say intercoolers?:)
Stock intercooler is a BAD place to start modifications.
It offers very poor value for money when you are chasing 'the basics' and specially with only the stock turbo.
If you have a budget of $3k or less leave it alone for now, and just make sure you have the other bases covered first.
Unless of course you are made of money (New turbo's?) or like losing to much less modified skylines in races.:)
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
