Rda Rotors Group Buy - The Next Generation
  • Replies 75
Great to hear guys... anyone from 3rd batch who has not received their rotors by this friday let me know via this thread or pm and I will follow up with RDA.
There were 3 people who misses out the 3rd batch as the transfer went in late but your orders has been submitted yesterday afternoon and RDA will ship them out today:
- JSWR32 (R32 GTR front 7926G)
- Leech (R33 GTSt rear 908S)
- NRB (R32 GTR front 7926G)
hey rianto
pmed you the other day. i was in the first group buy for the rotors. just wondering if its possible to get rotors for a honda accord? nothing fancy just plain rotors. got quoted $400 just for the rears by repco. even if i cant, even a 10% discount or something? if your too busy to ask for me im happy to enquire just need a number to call.
thanks jason.
They did it on purpose as of not to disclose the special price only available on SAU forum. Otherwise they will have issues with their big customers ringing up unhappy because they can't beat our prices.
Regarding how they balance their book, it's their internal thing to sort out. :teehee:
I am unable to open the zip its saying its corrupted
can you please pm me a quote for R32gts4 front slotted discs think they are the same as R32gtst type M discs or 280mm
Regards, mike
Hi Guys,
Just for "quality control" check do any of you from the following batches have not received your rotors?
3RD BATCH
- Paragon
- turbo87
- pssht
- GTshortie
- Will20b
4TH BATCH
- JSWR32
- Leech
Can you pls confirm whenever it's convenient...
Can you please double check with RDA on the rotors for the R34GTT; I was in contact with a local distributor yesterday and they said there is a part available for them.
Thanks
As per my correpsondence with RDA all these times the only ones we have for R34 GT-T is rear rotors which is the same as R33's
Do you have an exact Part No and rotor dimension, that might help a lot.
Hi, maybe in a week or 2. Right now I'm too flat out at work. Office caught fire, with me the only one working on weekends and single handedly fight the fire till the brigade arrived, jobs were delayed, so lotsa sh1t happening this week...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
