My intercooler has developed an unhealthy brown colour after dealing with years of exhaust smoke and crap like this.
I wanted to clean it, but the fins are quite brittle so i cant really use any contact on it.
I was thinking of using alloy wheel cleaner on it. Can anyone think of any reason why I shouldnt do this? eg. damaging the intercooler or something?
Has anyone tried it before?
https://www.sau.com.au/forums/topic/135634-cleaning-intercoolers/
Hi Jon!
Might sound silly but what about degreaser? A small mixture so its not as strong?
Ive never cleaned mine either - but then again its kinda newish!
Would be interesting to find out what others do :laugh:
Aluminium sucks for this reason, it tarnishes easily and you have to take a fine layer of actual metal off to get that clean look again, there are products that we use to clean up ali after welding it, it evil stuff though as it can cause bone cancer.
Primordial, I haven't tried cleaning my intercooler yet, but using alloy wheel cleaner sounds as though it shouldn't cause any harm. When it comes time I think it'll either be using alloy wheel cleaner or degreaser and make sure it's rinsed off well.
Just have to be really careful with the fins, just like the radiator core. The only downside I can see with the liquid/spray cleaners is how to get any solids, such as bugs and dirt, out without damaging the core?
What about the inside of the intercooler? Are you going to clean the inside as well? What are others opinions/advice on doing this?
Thanks for some great ideas guys!
Tomorrow i'm gonna pull the core off and give it a clean. I'm going to start with alloy wheel cleaner, and if that doesnt work, i'll try degreaser. I'm going to use a high pressure hose to blast the residue off (from a distance obviously!).
For the inside, I've heard that a 50/50 mix of metho and turps is the go!
Ill give it a go and let you know!
I read a tech tip from hot 4's and gave it a go ....don't know issue number
something like this
I removed the core taped a plastic bag to one end of the end tank then emptied 3 cans of degreaser into the core....
then taped another plastic bag over the other end tank.....
invert back forth then empty....repeat if real dirty then wash out with water.....
i used tap water but i imagine de min wouldn't harm........
stand so excess water can drain out ....
(leave in the sun)....hope this helps.....
whilst the cores off use tweezers to straighten fins.....and remove insects....I noticed a dif when I did this as the core had been on the car since I bought it....very dirty
hope this helps.
  • 1 year later...
Hot4's had a helpful tech tip!? :rolleyes: What the?
lol
sounds good, i might give this a go!
The soarer forums recommdended doing two treatments, first with just kerosene as this will disolve alot of the oil, but as well all know kero leaves a film of crap, then flood it again with metho which removes the layer, a 50/50 mix may leave some residue.
just a tip for you all i use a product called Shellite (also known as lighter fluid in some brands).
Shellite is a product called x55 from shell and is also used as automatic transmission cleaner as it is the fastest drying solvent, it is also the carrier used in tyre shine it drys off and leaves the silicone to coat the tyres.
Shellite (x55) is also brake cleaner i have displayed this to several mechanics who were paying up to $100 for a 20 litre drum of brake cleaner and i gave them 1 litre of shellite (x55) and they said that hey thats the same, i know it is because i used to pour shellite (x55) into 20 litre drums and place brake clean stickers on them and freight them to victoria.
a 50/50 mix of shellite and mineral turps is used as wax and grease remover.
to clean out my intercooler i pour 2 litres of shellite (x55) into it place my hands over the in/ outlet and shake it up and down then pour the now very black shellite out and let it dry (drys quickly as i said it is the fastest drying solvent.
Edited by black33gtst
best thing i have seen is high concentrate truck wash
as used on everyones dirt bike i know - spray on with high concentrated water/wash mix .. let it sit, then hose off.
alot of other suggestions have been for cleaning the inside of the cooler- but if you aint already taking the cooler out, try some C16 truckwash first.
  • 3 weeks later...
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
