I'm located in Adelaide.
FOR SALE:
*Set of 18x8 chrome wheels with tyres
*Spacers to suit big brake calipers
Chrome Wheels
Set of chrome wheels including tyres, perfect for that show style! Multi-fit 5 stud pattern to suit many makes and models. They're running 225/40 up front with 90% tread and 235/40 on the rears with 75%. 2 of the wheels have a little bit of gutter rash which is hardly noticeable. Only used for about 6 months. Unsure of offset but wheels will fit R33 with spacers (see below).
Bonus - set of lug nuts and lock nuts with key
Price DROP: $1000 ONO Pick up only
Spacers
A couple of spacers to suit big front caliper Skylines! Perfect condition. Very easy bolt on installation.
Price: $150 FIRM but if you like the wheels too I can do a good deal for you. Post at buyers expense.
Please PM me if you have any questions.
Edited by $weetDreamZ
  • 3 months later...
  • 1 month later...
Free shipping within Australia for the Momo gear shift knob! So no excuse for all you interstate buyers now!
Reduced price of castor rods from $30 down to $20. Pick up only for those though.
  • 1 month later...
New items added!
*18x8 wheels with tyres - excellent condition $1500 FIRM Pick up only
*2 spacers - perfect condition $150 FIRM Pick up or post at buyers expense
Price drop on castor rods - $15 Pick up only
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
  • 2 months later...
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
    • I don't think he's got it on a gauge and on the ECU. I think he's got it on the gauge and on the HPTuners DAq thingo. Remember, we're talking about oil temp here, not something that the ECU is actually interested in for its own sake.
