hmm you're right at least its different...
I think sohc engines are able to produce more torque (dont ask me how, its just what i've read - maybe something to do with one less cam + set of valves to spin..), and depends on whos played with the head porting and valves to see how it would flow?? Are the rb30 sohc heads 4 or 2 valve per cyl?? I dunno...
Alot of the vl turbos still retain the sohc head and make good power...must be a reason for that, unless they are too heartbroken to loose the holden stamped cam cover lol.
the green one built by rajab/bresciani? im sure it was one of those if its the same car, just cant remeber which workshop in particular
yep.....
yeah i think engine work was done by rajab racing.
owner is on here
Edited by R-SPEC
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
