James and Snowy spoke to him at Dutton and he will be joining up and coming to the show and shine from what I know.
James will clarify that though.
Iheard maybe the Autosalon stand..... its a maybe..
NOVEMBER
3/4/5 Fri/Sat/Sun – Melbourne Autosalon Semi Finals – MEMBERS ONLY
7 Tues - 11 Sat - SAU Takes on Sydney - Motorsport Road Trip to NSW - Click Here
18 Sat – DECA Motorkhana Day - Shepparton
21 Tues – SAU Vic General Meeting – 8.00pm - Bells Hotel, Sth. Melbourne
23 Thurs - SAU Vic Pizza Night
26 Sun- Christmas Party & Annual Show N Shine Day – MEMBERS ONLY
I talked to him not too long ago, he said he's very busy with his other clubs but is looking into the SAU membership :happy:
We spoke to the driver at Dutton VIC, and as he is a motorsport enthusiast he was more interested in things like DECA, rather than Autosalon. But we shall let him make up his own mind.
Great to hear it will actually be driven
I was at OranPark when it had its first outing after being imported - it has some niiiiice speed, and sounds awesome!
Make sure if you see it with the bonnet up you guys check the airbox, and if you see it sitting around, have a look at the diff setup - its well worth lying on the road for :happy:
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
