My car received its 100,000klm service the other day and I'm just worried that I am being ripped off. How much should I be paying for the individual parts he has changed? Your responses are appreciated.
EDIT: The total cost of the service was $1097.80
Items changed include:
Timing Belt -
Idler Bearing -
Tensioner Bearing -
Crank & Cam seals -
Water Pump -
Thermostat -
Top & Bottom Radiator Hoses -
Coolant -
I have attached a copy of the invoice he gave me for your perusal.
https://www.sau.com.au/forums/topic/13570-have-i-been-ripped-off-100k-service/
yeah, thats about standard for most cars, and most cars need a 100,000km service of some type - so its probably not way too over the top.
That includes a fair vital things such as water pump, and timing chain... it probably is fair
just for reference my 100k service cost
$650
spark plugs, fuel filter, oil filter, oil changed, timing belt, coolant, pipes checked
where yours cost so much would be the water pump and all the other parts that were changed in your service. did they really need to be changed??? ask yourself that.
they used cheap oil, and coolant so watch that
Originally posted by skyzerr33
timing belt is only $100 from nissan.
they didn't even do the gearbox and diff oil change but that usually gets done at 80k service
Yeah the gearbox was recond under warranty last month and all fluids changed at 80,000kms.
I suppose I didn't have to get the water pump changed but I thought that gets changed at a 100k service?
Depends on your water pump. Mine decided to retire at about 100,003kms, and hence my car went for service.
All up, I had engine oil & filter, spark plugs, water pump, timing belt, cam seals, crank seal, coolant & water, air filter, and a new radiator hose, all up parts and labour came to $820
An ordinary car can also rack up similar 90,000/100,000km bills.
My mum's Magna just had a $1,262 90,000km service.
Water pump, brake pads, timing belt, cam cover seals.... usual lubes.
I haven't had my 33 done yet but I am dreading the cost.
Hopefully I can do enough small repairs up to the big service (ie. timing belts, box/diff oil etc.)
T.
Thats a pretty good price, the tensioner bearings etc for the timing belt are pretty expensive. The water pump definately needs to be changed as well. Also new radiator hoses from nissan are about $50 each as well. Better to spend a little extra then the chances are you wont have any trouble for the next 100,000km if the regular stuff is performed.
why not do yourself what you can and then get the mechanic to change what you can't - save yourself $$$ and you know exactly what goes in and how much it really costs rather than just what they have told you.
i have a mechanic which i only go to if i can't do it myself (but he's a friend and does it cheap anway!)
Labour at $180 seems pretty cheap to me considering what they did, that's only about 2 or 3 hours work. The parts cost though I've got no idea.
Do the idler and tension bearings really need to be changed? Even though my timing belt was done at about 80k, I'm wondering if at the 100k I should also do the bearings.
If he's a good friend of your dad's then I doubt he'd rip you off on the parts if he did a good price on the labour. The bearings and seals must have cost the most. Timing belt, 2 hoses and thermostat shouldn't cost more than $250 or so combined.
I'd be a bit worried about that oil though, if he's used standard pricing on that like most other workshops do you'll find that he's probably put in something inferior to the GTX2 you can buy in Woolies. If however he's charged as if you bought it from Auto 1 or the like then it'll be a high grade mineral oil or an average grade semi or full synth. Try to find out what he's put in exactly.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
