I was driving alone today my suddenly theres no pressure in my clutch pedal and soon after that i could not engage into gears, any know know what the problem could be ???
hopefully i dont need a new clutch fingers crossed !!
Thanks
Check your slave cylinder on your gear box man :happy: Or your clutch master cylinder on your fire wall.Had my slave cylinder totally blow the seal on me one day... And the pedal went to the floor... :ermm:
Check your slave cylinder on your gear box man :nuke: Or your clutch master cylinder on your fire wall.Had my slave cylinder totally blow the seal on me one day... And the pedal went to the floor... :D
Yeh my dosent go to the floor it bounces back up just not pressure really light and can not change gears !
haha this what happened to me lastnite ....just rang nissan ...total of 25 bucks for the seals...the slave cylinder for the clutch folk was mine...fluid pissed out everywhere. To get it going you have to put into gear first then start car up n make sure nothing infront of u or ull go right up their arse!. was a shit coming to a stop tho!
whats the best clutch fluid to use? nissan one?
was only 17 dollars for the slave cylinder seal kit.....was easy job to do. just have to adjust my clutch engagement now..feels as tho the clutch has to b pressed further down before it bites...strange tho used to get crunch when i go into 4th gear real fast..now it doesnt do it??? any suggestions?
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
