Put the new kit on the 32 today geting custom pods made for the ass end going to look mad when i have finished with it.
Will be painting it throw out the week will keep yas updated.
Let me no what you all think of it.
https://www.sau.com.au/forums/topic/135839-put-my-new-kit-on-the-32-today/
i love that front bar, not to keen on the add on's you did yourself but its your car so if its to your taste then thats all that matters. Be good to see when the cars been painted
lol spent a long time on the indicators had to heat them up and remove all the orange out of them and yer then played with a bit of paint on them looked good after we fin with the tho
looks hot without the bonnet lol. Why did you take off your manifolds. Are there big mods i dont know about... Is that bonnet fibreglass or did you just cut your existing bonnet?
Edited by r_speedfreak_r
lol that pix with the manifold off its my bros gts4 just droped the 26 in it and yer big mods going on with that car only spent about 15g on mine.
Yer it is a stock hood with holes cut out of it may put perspects in it i have mesh in it at the mo
Looks good apart from the bonnet cut out, no offence intended - just not to my taste. Not too crazy about the front splitters/extended lips either. Sorry.
I'd love to be able to do bodywork. Plenty of money to be saved if you can DIY.
Good luck with it.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
